To Catch can or not to catch can…???
Old Jun 8, 2012 | 09:54 PM
weap0n's Avatar
You don't need to remove the bumper. Lol.
If you actually researched that catch can you can access it after pulling some of the clips of the undertray.
Old Jun 9, 2012 | 03:58 PM
BaumBizzle's Avatar
Hmmm must've overlooked that then...thanks for the heads up man!
Old Sep 24, 2012 | 11:59 AM
Vostok 7's Avatar
Originally Posted by flymx771
The PCV valve is garbage and leaks on most of these cars. When you get into boost it will allow air to pass through which pressurizes the crankcase. This usually causes the dipstick to pop out since the breather on the VC can't relieve enough pressure. It also makes for difficulty in the return of oil to the pan.
Best thing you can do is run a line from the PCV port to a catch can then put a quality check valve in-between the catch can and the manifold. Then, enjoy not having oil inside your manifold!
Which way would you point the check valve?
Going to put a dual catch can system in soon, getting a lot of crap in my UICP.
I also learned well what happens when that breather hose gets kinked
Fstyles05EB
Jan 31, 2017 04:39 AM
David Buschur
Aug 12, 2012 07:39 PM
LakerRaider
Mar 27, 2011 06:40 PM
David Buschur
Nov 23, 2010 05:57 PM
vtluu
Aug 10, 2006 08:56 AM
