Walbro 400 - E85 version
I get that on the low voltage, low load output direction from the ecu. Wouldn't it be easier just to upgrade your FPR to an adjustable unit and then fix the voltage at battery level than risk damage to the pump by forcing a big pump to operate slower and at a lower voltage than designed?
i am running an AFPR... but
a) I dont want to run less than 30psi base, because I think the spray pattern suffer
b) My return system doesn't allow for less than 35psi with the E85 400 pump
Why will the pump be damaged at lower voltage? Is that something common for electric motors?
the trims are fine.
my main problem is that the 1.15 odd IPW that the injectors need to run 14.7 is a bit too low for the injectors to run at reliably..
hence when I have lowered the fuel pressure to 30/35, so that I need a higher ipw.
but if I can also reduce the flow with the pump (by lowering the voltage) then that might help as well)
been there done that with the low voltage resistor on my w400. with a 0.55 ohm resistor, the pump would run at engine idle where the fuel rail pressure was about 37 psi, but as soon as rail pressure passed about 40 psi, the pump would stall. with the stock resistor, i found that the pump would stall if i raised the full voltage xover to more than the stock value of 100 load. i actually ended up going to a higher than stock resistor so that i could run higher than stock xover load because pressure across the injectors would jump about 10 psi above the 43 psi target when triggering at 100 load and would stay high up to about 150 load. i'm getting slight overrun at idle, but nothing like what you mention.
thanks mrfred,
I dont think my pump stalls with the stock resistor even upto 55psi... my load xover is 140, and when passing that I dont seem to notice the AFR going rich or anything like that (to indicate a massive increase in pressure)
so did you run 2 resistors or just the stock one?
thanks mrfred,
well ive had both Walbro 400 pumps no (regular and E85).
To be honest I havn't tried driving the E85 one above 45psi, but the regular one operated fine between 30 and 55...
my normal Walbro400 has had no issues and has ONLY seen e85. I got it when they were very first released. Base pressure 40 and ramps up to 85-82 under WOT, no issues ever. It is ran parallel w/ a 044, both maxed currently. LOL. Currently looking into a KB BAP
