Zfr 3" intake anyone?
Curious if anyone has this or has seen it in person. Pics look nice, plus it has a 3" turbo inlet piece. Here's a link http://www.ebay.com/itm/ZFR-EVO-X-EV...6#ht_500wt_689
That intake in the picture looks exaclty the same as the AMS intake. The difference is that the ebay one comes with the turbo inlet. It sounds like a good deal, but I'm not one for unknown brands and such. I'd worry about fitment and quality of the pieces.
I took a chance on it and got it. I payed $220 shipped. I saw that it looked really close to the AMS intake. Once I got it I took measurements and compared it to the AMS and its the same. It even came with the K&N filter like the AMS one. its stainless and does not come with breather bungs. I drilled out two holes and put I rubber grommets so I could hook up my vac lines. I also have a cobb tuner and just put in the AMS intake map and it works fine I haven’t had any problems with it at all. It sounds just like the AMS intake, Down side is you dont get the heat shield.
I didn’t use the 3in turbo inlet. I figured AMS didn’t see a need to so I didn’t see a need to either. As for the vac lines I put in 2 rubber grommets ( can get them at Lowes), Then just hooked up the lines to the intake. Make sure your rubber grommets fit tight and you shouldn’t have any leaks. Down side to the intake is it does not come with the heat shield like the AMS one and the screw holes for the air sensor are a different thread pattern so your stock screws won’t work. It is made from stainless and its pretty tough the finish looks pretty good as well.
D Walk3r
Mar 21, 2015 12:22 PM
Justin at STM
16
Jul 24, 2012 10:34 AM
Evolessfornow
Oct 10, 2010 08:16 PM
