Boost problem
Old Sep 8, 2012 | 01:45 AM
sonic_evox's Avatar
Boost problem
Hey guys, ive been having a weird boost issue, it could be a boost leak im not 100% sure, im suppose to be at 24-26psi of boost, lately im only getting to 14-15psi, ive checked all my vacuum hoses, i even at one point thought it was my 3 port boost controller, i had that replaced and noting. I checked my turbo piping and all seems to be well installed, i dont hear any leaks or any weird sounds, im totally lost on what to do, ive looked everywhere, i dont have access to the right tools to do a boost leak test, so what do you guys suggest? or where have you guys found common boost leaks? My car feels really sluggish, help guys
Old Sep 8, 2012 | 02:10 AM
EV0L-IX-MR's Avatar
Honestly find a way to do a boost leak test
Old Sep 8, 2012 | 04:49 AM
MisterHappy's Avatar
Go to a local shop and have them run a boost leak test. either that or start re-tightening everything on the car to try and find it.
Old Sep 8, 2012 | 05:50 AM
ravenjam's Avatar
The best way is a boost leak test. If you dont have access to a compressor, i would suggest pulling off and going over all vacuum hoses and IC piping. Ensure you are using t-bolt clamps since you are running that much boost.
Recently I had a somewhat similar issue. My problem turned out to be a sticking waste gate. Couldnt hurt to check.
Old Sep 8, 2012 | 02:36 PM
sonic_evox's Avatar
Thanks for the info guys, might have to remove everything and double check all my hoses and piping
1 evo8 1
33
May 8, 2020 02:14 AM
vr4gasmtt
Jun 14, 2015 10:12 PM
iStubz
Apr 10, 2014 09:25 PM
awdordie
Feb 22, 2014 01:14 PM
baylorar
Jan 13, 2009 10:00 AM
