Convert SST to Manual
Old Sep 25, 2012 | 02:06 PM
Rallyman's Avatar
I am converting an SST to a Drenth sequential gearbox with pneumatic paddle shifter controls for racing and rallying and I need some advice.
Do you know whether or not the Left Hand Drive Shaft on an SST is the same as that on a GSR or is the output spline different. We seem to have a problem and I need to find a solution quickly.
If these drive shafts are not interchangeable, does anyone have a Left hand drive shaft for a GSR that I could buy.
Old Sep 28, 2012 | 01:21 PM
EAGLE 5's Avatar
You could look on e-bay and hit up a lot of forums to see if someone is selling one. Or you could go straight to an aftermarket unit like Driveshaft Shop's or even a carbon fiber one.
If you're going through all the trouble to switch out the transmission to a racing sequential you can go all the way and get a solid aftermarket driveshaft.
DSMLINK2003
Jun 5, 2015 07:11 PM
M.Yizzle
Jan 30, 2011 08:05 AM
Rallyman
23
Mar 30, 2010 09:15 AM
Boba
Mitsubishi TC-SST Discussion
Jan 6, 2010 10:59 AM
desperado-c
Aug 8, 2008 04:58 PM
