Should I get cams? FP black stock block
Old Oct 9, 2012 | 09:00 AM
mct9891's Avatar
So I'm at 420ish whp and 340wtq, which is where I want to be for reliability purposes.
I wouldn't be getting the cams to get more power so is there any OTHER reasons to upgrade cams . Would probably get GS2's or kelford b with springs.
Thanks
Old Oct 9, 2012 | 09:02 AM
Kracka's Avatar
Zero reason to get cams if you're happy with your current power.
Old Oct 9, 2012 | 09:08 AM
mct9891's Avatar
figured that, thanks!
Old Oct 9, 2012 | 10:48 AM
jyamona's Avatar
getting either of those cams would definitely give you more midrange power and you could probably keep your same peak #'s you have now, but run less boost to get them
Old Oct 9, 2012 | 01:37 PM
Spazpilot's Avatar
Cams are a lot of work if you do them yourself and expensive if you have someone else do them. Like Kracka said zero reason to buy if your happy with the power and the mid power gains would not be worth the headache of buying buckets/Tappets to get the right valve clearance and removing the timing chain.
Old Oct 9, 2012 | 07:22 PM
toodrunk2see's Avatar
If you plan on building the block it wouldnt hurt to get the cams for the build but like others have said kind of pointless until you are pushing the air flow to use them.
Old Oct 10, 2012 | 11:45 AM
murlo26's Avatar
Stock longblock seal, don't break it
Old Oct 12, 2012 | 02:06 PM
Travis@GSC's Avatar
cams get you laid
Old Oct 12, 2012 | 02:10 PM
DsmGuy86's Avatar
^ Hahahahaha that they do I would say some s2s for sure they go hand in hand with a black and like stated you can of you want keep your peek #s but use less boost and that's what helps longitivtiy of the motor an I love the s2s personally
Old Oct 12, 2012 | 03:56 PM
Kracka's Avatar
Originally Posted by Travis@GSC
cams get you laid
Until the car stalls when coming to a stop at a stoplight
Old Oct 12, 2012 | 11:23 PM
Alpha X's Avatar
Would GSC S1 Cams cause that?
Old Oct 15, 2012 | 06:05 AM
Travis@GSC's Avatar
No, S1 and S2s are run in a lot of daily driven cars that don't stall at stop lights. But its more about the tune than the cams.
Old Oct 15, 2012 | 06:13 AM
Kracka's Avatar
S1's will be much more bearable for a DD street car (assuming proper tuning).
Old Oct 15, 2012 | 07:35 AM
murlo26's Avatar
s2's on my built 2.0L were not quite as nice as on my 2.2L.
Displacement helps, but more importantly proper MAF and MAP scaling. s2's idle fine now at 840rpms for me
Old Oct 15, 2012 | 09:07 AM
sssp's Avatar
I run the Kelford B on the stock block with springs. No stalling problems, drives great
