Should I get cams? FP black stock block
Old Oct 15, 2012 | 12:35 PM
FrancescosEVO10's Avatar
stock block + cams at the power your at now. i would invest in building ur buttom end first before you are in the same boat as me
what kind of fuel grade you running?
Old Oct 15, 2012 | 01:33 PM
mct9891's Avatar
93oct, guessing you blew your motor =/
Old Oct 30, 2012 | 08:08 PM
Showbizz41's Avatar
Originally Posted by Spazpilot
Cams are a lot of work if you do them yourself and expensive if you have someone else do them. Like Kracka said zero reason to buy if your happy with the power and the mid power gains would not be worth the headache of buying buckets/Tappets to get the right valve clearance and removing the timing chain.
Exactly this... I had the S1's put in a long time ago.. The springs and retainers are not a requirement with them, which was my original thinking.. A handful of mods later, the black and a tune or two later, now I almost wish I went with the S2's from the beginning. When I do my motor build I'll prob stay with the S1's. Moral of the story, strongly consider what you will be doing down the road and really how far you will go... If you wanna go big, then get the right cams for the future
Justin23
Jan 3, 2017 08:32 AM
svt_lightning01
Feb 9, 2011 01:10 PM
Preludepearl417
Sep 4, 2009 07:51 PM
redevo58
63
May 27, 2005 12:09 PM
hardcoretuner
Feb 15, 2004 07:53 AM
