turbo spooling sound...
Old Apr 23, 2013 | 03:21 PM
wowitswil's Avatar
always had this question....how come some cars are able to sound like this...where u could hear the turbo spool....i never hear it on mines...EVER...am i not using the right intake system?? cause my set up looks like his...just that i dont have a complete intake hose....part metal n part stock rubber...can that be the case?
please would like some input...
Old Apr 23, 2013 | 07:00 PM
mshilto89's Avatar
Depending on which intake setup (amongst other things) can make different sounds.
Old Apr 24, 2013 | 09:27 AM
wowitswil's Avatar
jus ordered a ets to replace the takeda i have on....to see how that turns out also ordered a synapse dv..wonder if thats gonna change anything
Old Apr 24, 2013 | 09:33 AM
Madsta's Avatar
I use an injen and damn can you hear my turbo
Old Apr 24, 2013 | 10:01 AM
CurseDSM's Avatar
It has to do with turbo cold side size, size of the intake pipe and what filter (filter not so much) but it has to do with all the air being sucked into the turbo.
Old Apr 25, 2013 | 03:04 PM
NeedBoost!'s Avatar
Ok what I don't understand is how that video looked like he was on a dyno?
Did he put it in drive, smash the brakes, and give it gas???
I don't buy auto-trans vehicles, so maybe there's some magical wizardry I don't know about, but that didn't look right.
If you have a cone filter, you should hear your turbo at least a little. Don't try hearing it while at a standstill or parked - your turbo shouldn't be spooling a ton at a standstill unless you're floored.
Also, this guy probably had a tune so he is running a lot more boost than you if you are on the stock tune.
Old Apr 26, 2013 | 05:20 AM
deadbeatrec's Avatar
that looks like hes putting load on the motor, not just revving it. like he has the brakes on so the car doesnt move while it slips the clutch.
has to be, the turbo wont spool like that without load.
Old Apr 26, 2013 | 08:13 AM
r34p3rex's Avatar
Our turbos are too big to spool without a load. I think he had the e-brake on and slipped the clutch while giving it gas.
Other cars with smaller turbos on the other hand.. the turbo will spool up a bit even without load
Old Apr 26, 2013 | 08:35 AM
blown65's Avatar
I had the same one, and could hear it very well.
Old Apr 26, 2013 | 06:55 PM
wowitswil's Avatar
does the uicp have anything to do with it too??
cause im already running tuned...just installed my synapse valve (recir) still dont come close to that...
Old Apr 26, 2013 | 07:07 PM
MauroEvoVIII's Avatar
its a x MR so i think he was in drive stalling it up thus putting load on the car spooling the turbo. just an opinion
Old Apr 26, 2013 | 07:18 PM
wowitswil's Avatar
isnt that consider a fail launch attempt?
Old Apr 28, 2013 | 12:49 PM
Cellar Door's Avatar
A solid metal intake pipe and an open air filter element will get you that sound. Any soft materials like rubber/plastic dampen the sound and reduce its volume.
Old Apr 28, 2013 | 02:35 PM
cfdfireman1's Avatar
Jack the car up so all 4 are off the ground put it gear with foot on brake and let it spin up as you modulate the brake, simple.
Old May 12, 2013 | 04:01 PM
MattACK's Avatar
have the ETS intake and it spools up nice and loud.
