P0303 Misfire only in boost
Old May 31, 2013 | 02:59 PM
ErikPhilips's Avatar
I did a lot of research on this forum, tuners, technicians and couldn't find a solution that worked.
First I tried swapping coils 3&4 but the error code stayed on Cylinder 3. Tried replacing the spark plug, no go. Was about to get a compression test on 3 (luckily for free from a friend), but I remember seeing Tobz Performance around where I was, called him up and he was nice enough to take me right then and there. He then fixed in about 10 minutes.
The problem was apparently my Fuel Pump relay went bad, but only for the high voltage part, so no boost worked fine, but boost was running super lean until misfire. Just my personal experience, hope it helps someone else out in the future.
Linky https://www.evolutionm.net/forums/ev...ay-1-test.html
Old Jun 3, 2013 | 03:06 PM
01CBR929's Avatar
Thanks for sharing! It helps when people state both their problems and what they did to fix it.
Old Jun 26, 2013 | 06:52 PM
Evobigz's Avatar
This is an interesting find, I am plague with P0300 code. I have checked everything except this. Hmmm
mrfred
383
Jul 16, 2024 09:29 PM
Mike W
84
Aug 19, 2016 08:36 AM
dcevox
May 13, 2015 03:14 PM
SSP Jeremy
EvoX 'For Sale' Electronics / Lighting / Audio
79
Apr 28, 2015 09:17 AM
