OEM NGK Spark Plug Electrode Ground Broke Off
Old Jun 9, 2013 | 01:36 PM
MadBoostedEvo's Avatar
I'm sure this topic has probably been covered in the past.
The cars has 10,266 miles. I tried getting into boost last night and the car started sputtering and would not boost. At idle, it would missifire. I had a suspicion that somethng might be wrong with the spark plugs and started taking the coils and plugs out. Sure enough, pulled plug #3 and found this:
Old Jun 10, 2013 | 04:33 AM
mshilto89's Avatar
Did you get the ground out?
Old Jun 10, 2013 | 06:17 AM
Jake.barratt's Avatar
Same thing happend to me on my 2012 GSR with 4k Miles. To say the least I was pissed. Is there an aftermarket spark plug that is better than the OEM ones?
Old Jun 10, 2013 | 01:52 PM
I did not
I'm hoping that it went out the exhaust valve without damaging anything.
I will be doing a compression test and will also be going to a shop to get a videoscope in the block to make sure the piston, walls, and valves are not damaged.
From my research, the 08-10 Evo X's use a different plug than the 11+.
NGK ILKR8E6 (2008-10 models)
NGK DILKR8B6 (2011+ models)
I ordered a set of ILKR8E6 from O'Reilly. You can get them cheaper online, but I needed them the same day so I had to pay $80 + tax for all four plugs.
Old Jun 11, 2013 | 08:14 AM
Kracka's Avatar
You can get a set from the dealership for about $55.
Old Jun 11, 2013 | 08:16 AM
Kracka's Avatar
https://www.evolutionm.net/forums/ev...-failures.html
Old Jun 11, 2013 | 08:26 AM
Nickygixer-k5's Avatar
It happened to my friends evo x running a cosworth engine 2 weeks ago, damaged the head and valve. He mentioned that previously he was running HKS plugs with no issues apart from cost.
Old Jun 11, 2013 | 11:45 AM
Im curious if the HKS plugs are better from OEM. Everyone seems to just keep using the OEM ones regardless if they keep having failures.
Old Jun 11, 2013 | 06:40 PM
Hmm.. That's weird because the stealership told me $100.
Old Jun 13, 2013 | 08:17 PM
jdmimprez's Avatar
Also curious if the HKS plugs are worth the higher cost.
Old Jun 14, 2013 | 06:54 AM
Kracka's Avatar
$54 from my dealership.
Don Herring Mitsubishi - Irving, TX
DonMitsu is his screen name on here; he is an EvoM sponsor.
Old Jun 15, 2013 | 03:46 PM
I couldn't say but I know he is switching back to HKS once his car is back on the road, once bitten and twice shy and all that.
MadBoostedEvo
For Sale - Wheels / Tires
Feb 28, 2016 09:04 PM
MadBoostedEvo
Evo X Dyno Results
35
Jan 13, 2016 09:56 AM
MadBoostedEvo
19
Jun 7, 2015 05:49 PM
MadBoostedEvo
40
May 1, 2014 06:38 AM
MadBoostedEvo
Aug 8, 2013 09:17 AM
