Hissing Noise under heavy acceleration?
Need some help please.
Breif background I have a 2008 Evo X GSR 51k miles with Invidia TBE (Catback + Invidia DP/test pipe combo), AEM Intake, AMS Tune, AMS UIP, one year old Spec Stage 3+ Clutch and fidanza aluminum flywheel.
Ok, onto the problem. When I am cruising everything sounds fine. But as soon as I press the gas pedal down hard (but not WOT) I hear a very loud hissing/air blowing noise. As soon as I let off its gone. Any ideas?
Thanks!
Thanks!
I had a loud hiss after installing my downpipe. It was leaking at the gasket between the downpipe and the turbine housing. Just a thought. Like stated above. look for boost leak and check your exhaust gaskets for fouling that would indicate a leak.
