ACD/AYC Pump Heat
Old Aug 25, 2013 | 08:04 AM
Visual1's Avatar
ACD/AYC Pump Heat
Hello,
How hot does a ACD/AYC Pump Get?
A little background into my situation. I live in Canada, my pump died, and when I tried to rebuild it, it was so corroded that the aluminium and plate crumbled.
I am considering moving it to the trunk. It looks like it will move easily after I make some new lines and a bracket. My only concern is the heat the pump will generate. Any ideas if it is too hot?
Cheers
Old Aug 25, 2013 | 05:02 PM
kikiturbo's Avatar
it will not corrode again if you take care and seal it well when overhauling. The additional problem on the Evo X is the motor which looks more fragile than the earlier units, and is not as easily servicable. The pump is also not as well cooled as on the earlier cars and I think this is also a part of the problem.
Old Aug 26, 2013 | 04:37 PM
SamsonEvoX's Avatar
My son's AYC pump just took a dump on him yesterday. Temp was about 97. AYC started flashing. He took his X to a dealer and yes, the pump had severe corrosion and needs to be replaced. Good news is that it will be fixed under warranty. I just hope that this does happen again in another 2 years as he has a 2011 GSR and has driven it through 2 winters.
Old Aug 27, 2013 | 06:48 PM
kikiturbo's Avatar
apply silicone sealant on the joints between two parts of the pump body, and between the motor and pump body, and also apply heavy grease on the bottom of the solenoids, where they enter the pump body..
Old Aug 29, 2013 | 12:26 AM
9gt's Avatar
9gt
kikiturbo, do you stock the X repair kit for acd pump (evo X RS model)
cheers
mike
Old Aug 29, 2013 | 07:57 PM
kikiturbo's Avatar
yes I do.. you can contact me via the email in the video below..
danfalcas
Feb 4, 2016 08:18 AM
silentsniper605
15
Oct 14, 2015 05:33 AM
ChipperEvo
Sep 24, 2015 12:36 PM
Iowa999
18
Oct 6, 2013 09:51 PM
nismo05
24
Apr 25, 2013 12:03 PM
