Gtx3576r or gtx3582r
Old Feb 3, 2014 | 12:04 AM
Blumenthal300s's Avatar
I was wondering whats the best turbo both stock location turbos from atp turbo im looking for the difference in both at like 26 psi and torque has to be at 370 max with stock evo x mr tranny with stock engine looking too get 470 whp
Old Feb 3, 2014 | 07:48 AM
spdracerut's Avatar
Give this article a read:
http://www.motoiq.com/MagazineArticl...e-Matters.aspx
You'll probably want to calculate a few numbers after reading it, so get your calculator out.
Old Feb 3, 2014 | 07:28 PM
IRPerformance's Avatar
The GTX3582 has more power potential with very little additional lag over the GTX3576. You will want to built the trans at some point anyway as it won't last at those power levels anyway. I'm going with the 3582 in a couple weeks. Go big or go home.
Old Feb 4, 2014 | 08:19 AM
LOVEMYX's Avatar
Hell Ya Thats what im looking at as well!
Old Feb 4, 2014 | 01:37 PM
CBRD's Avatar
I REALLY like the gtx3576R-
we have had some serious surge issues with the GTX3582 variant
cb
Old Feb 4, 2014 | 05:40 PM
cb
Really? What size inlet were you using? Surging is usually caused by a lack of airflow. What is the setup on the car like?
Old Feb 4, 2014 | 05:41 PM
I wonder if we ordered 3 of these at once could we get some sort of price break?
Old Feb 4, 2014 | 08:09 PM
an0therh22's Avatar
I have a 3582r and no surging issues to date. I'm running the 4in inlet with a 3.5in intake though so I'm not sure about guys with the 3in inlet. Anyways it does have more lag then what I wanted but i can live with it for now. I had to have a custom intake and uicp made for this variant so you may want to factor that in before getting a 4in inlet. The amount of money I invested in this turbo I could have just sold my bolt ons and got an ets t3 kit.
Old Feb 4, 2014 | 08:12 PM
spdracerut's Avatar
FYI, page 3 of the article has a direct comparison of the GTX3576R vs. GTX3582R on a STI. Same car, same dyno, same turbine housing.
Old Feb 4, 2014 | 08:49 PM
an0therh22's Avatar
Honestly if you arent running a 2.2 or larger youll get bored of the gtx82 rather quick. I don't hit full boost till ~5200 rpm.
Old Feb 4, 2014 | 09:14 PM
Good point but does anyone know the exact setup of that evo? Cams?
Old Feb 4, 2014 | 09:45 PM
Crap I got my numbers mixed up. I was thinking of the 3076 which doesn't really have enough compressor for the turbine size.
Old Feb 5, 2014 | 08:01 AM
CBRD's Avatar
We were running our LMP kit with a 1.03 hotside (biggest offered in Vband) with a 4" intake and antisurge cover-
you cant give it more airflow than that- our standard billet 3582 doesnt surge- nor did the 3576GTX in the smaller A/R hotside-
we have had some issue with new garrett Aero surging-
I would recommend the 3576 or consider other options, ours, FP's etc-
cb
Old Feb 5, 2014 | 08:02 AM
CBRD's Avatar
Id like to see the setups you guys are running- i have plots on 2 liters of our 35R setups hitting 25psi by 4200 rpm-
cb
Old Feb 5, 2014 | 10:21 AM
an0therh22's Avatar
Im running s2 cams with an ets manifold. No port work on the head or the intake manifold. I'm not sure if my lag is normal or due to the larger diameter inlet but I would love be to spool in the 4ks
I can also post my plots if you want to see
