Shifter problem
Old Jun 8, 2014 | 09:00 AM
Luminox's Avatar
Shifter problem
Hey! im pretty sure my shifter has a problem (First manual car) i need help finding what may cause this : Video of the problem
The car is used. I still have a warranty with the dealer. The car goes in gear and the gears works.
Old Jun 8, 2014 | 08:28 PM
Thomar's Avatar
You always yank it in gear like that? Holy moly.. No wonder your return spring broke.
Old Jun 8, 2014 | 08:44 PM
detroit pistins's Avatar
Have you done anything to the shifter? installed an aftermarket unit...etc
On the evo 8/9 design this would usually happen if the spring gets out of place or was installed incorrectly. You can remove the center console and inspect it. here is a pic of the evo 8/9 setup.
Old Jun 9, 2014 | 04:20 PM
Luminox's Avatar
Previous owner may have installed a short shifter. I llok into the spring issue
Old Jun 9, 2014 | 05:19 PM
Luminox's Avatar
Spring looks OK, need grease, i added a lubricant and it was much more smoother than before, still won't go in the middle by itself but a gentle push is enough to put in in position. Will buy lithium grease and see if everything is going to be fixed.
Old Jun 10, 2014 | 02:40 PM
The spring is very tricky when getting installed, I suggest you check it again and maybe snap a pic for us
TWM Performance
Feb 28, 2017 07:36 AM
Jseda845
Oct 22, 2016 05:28 PM
THE4TH
13
Dec 29, 2015 07:58 AM
lanberg
Feb 16, 2012 10:45 AM
sykou
Lancer Tranny/Drivetrain Tech
Mar 3, 2011 05:19 PM
