Changing ATF SP3 on AYC
Old Oct 21, 2014 | 08:00 AM
DaEvoPusha's Avatar
There's 129 threads online about this. I thought you could drain and fill the ATF SP3 on the torque transfer side.
I was talking to a guy at the dealership the other day that said it has to be bled with the MUT-3. I'm hoping he is wrong.
Has anyone changed the SP3 themself? I thought it could be changed with a simple drain and fill because the fluid in the pump and lines is separated from the fluid bathing the clutches in the AYC.
Old Oct 22, 2014 | 01:21 PM
cravnpup's Avatar
I drained and filled mine at the rear diff. Topped off the trunk tank, drove for a bit, then checked the trunk tank again to make sure it stayed topped off. I haven't had any issues, but that doesn't mean my way is best.
Old Oct 22, 2014 | 03:39 PM
05OrangeSS's Avatar
It's a drain and fill unless you run the reservoir dry
Old Oct 23, 2014 | 08:48 AM
DaEvoPusha's Avatar
Makes sense. I'm going to try your way.
How often do you guys change the side with SP3?
Old Oct 23, 2014 | 09:59 AM
cravnpup's Avatar
I do it every 15k or so. FYI, the fill hole is a ***** to find. Definitely look it up before you start. I found 3 that were blank holes before finding the actual fill.
Old Nov 2, 2014 | 05:44 PM
lippy1306's Avatar
Just drain and fill.
Old Nov 3, 2014 | 08:37 AM
Unblow's Avatar
Drain and fill ..actually the trunk reservoir oil doesnt drain if you drain the rear diff section..Did mine at 20k no problems
DrivelineSales
Oct 23, 2013 02:47 AM
dek0026
Feb 5, 2013 05:55 PM
Xchild4584123
Pacific Northwest
Mar 18, 2012 06:21 PM
BoostedXevo
Jul 20, 2010 10:34 AM
