Switch to Evans Coolant, Use Coolant Additives, or stick to basic 50/50?
Old Mar 19, 2015 | 09:05 PM
Roen's Avatar
Car is driven in the Northeast, both on the street and on track.
Car currently uses 50/50 mixed with Water Wetter.
Car is approaching 60k soon, and will be going through a coolant change.
Looking for opinions on what to use for this primarily street driven car:
Evans High Performance Waterless Coolant
50/50 with Water Wetter
50/50
I know the adage, if it ain't broke, don't fix it, but would like to have some thoughts on these three choices, or any others that I might have missed.
Old Mar 19, 2015 | 09:39 PM
ghozt's Avatar
Due to what I understand is a good coolant system from the factory, I don't think it matters. I use 50/50 with water wetter or purple ice. Live in Texas and seems to be good.
Old Mar 20, 2015 | 05:22 AM
hispanicpanic's Avatar
water wetter isn't needed on a 50/50 mixture and is less effective the higher the concentration of antifreeze is.
From the limited research i did on evans, it has a higher specific heat than antifreeze, which means the ability to cool will be reduced. Not great if you track, but not a big deal if its a DD/autocross car.
If you do like to track, but must keep anti freeze in your system, i'd reccomend the standard 50/50 with the motor max additive. The stuff is thinner than alchohol and dissipates heat just as well, maybe better. Really increases the ability for coolant mixtures to ditch heat.
http://www.ebay.com/itm/like/400870302871?lpid=82&chn=ps
huevosrancheros
Sep 27, 2012 06:14 PM
DKC6691
Jul 24, 2010 06:50 AM
dbdude
Aug 6, 2006 06:25 PM
Thoe99
Sep 1, 2005 11:40 PM
