Evans Coolant Has anyone used it?
Old Apr 13, 2010 | 06:47 AM
DKC6691's Avatar
Has anyone used evans coolant in an evo yet? Supposidly it has no water in it but has a much higher boiling point and is a true lifetime coolant?
Please comment if you have used this or know someone who has.
Thanks
Old Apr 14, 2010 | 02:52 PM
DKC6691's Avatar
anyone I would think with all the heat our motors make this inexpensive fluid would make a difference?
Old Apr 14, 2010 | 08:37 PM
TommiM's Avatar
back in my old mr2 days,many years ago, they were talking about this stuff on the boards. I know someone who used it with no issues, but at the same time no dramatic improvements either. It lets you run hotter coolant temps without boiling over as easily. Its really only beneficial if your engine is tuned and setup to run much hotter and you need more protection. Nascar engines run really high psi coolant pressures, ~45 psi iirc, to increase the boiling point of the water to keep from boiling over from drawing all the heat away from those engines.
Are you having issues with overheating? If its for racing purposes you might be better off just upgrading your radiator.
Old Apr 14, 2010 | 09:07 PM
evo8daddy's Avatar
i run evans coolant, this **** is expensive but it works great!!!! IT IS ACTUALLY ILLEGAL in some states, however i have had no probs with this coolant!!!
Old Apr 15, 2010 | 06:58 AM
94AWDcoupe's Avatar
I ran it. it made the A/C not work so well from the elevated radiator temps. It doesnt cool better. It cools worse. But as stated you can run higher temps with the stuff since there is no water to boil. Its impossible to get water out of block with head on. Really should only be used if engine is out and you can get system completely dry before using it.
Old Apr 15, 2010 | 07:24 AM
barneyb's Avatar
The idea of lifetime coolant seems silly to me since about every car project I do includes draining the coolant.
Old Apr 20, 2010 | 09:09 AM
DKC6691's Avatar
thanks for all the responses, reason being I am going to a fully built motor 10k rpm motor with an fp black and figured while I am in there what the hell.
Old Apr 20, 2010 | 10:54 AM
iTune's Avatar
It's not needed in most cases, this is for strictly full race engines. If you're trying to increase coolant performance, try something like "water wetter" by Redline.
Old Apr 20, 2010 | 07:21 PM
TommiM's Avatar
Were you monitoring your coolant temps with your previous setup? Were they above normal?
Old Jul 24, 2010 | 06:50 AM
flyingscot's Avatar
i used this in my track car and had no overheating issues whatsoever,i like it
kyoo
220
Dec 11, 2018 01:32 PM
evane
11
Mar 10, 2013 02:39 PM
Mrauto50
Feb 1, 2012 01:22 PM
evane
Feb 12, 2009 09:01 AM
4G63Rules
For Sale - Cars For Sale
Mar 17, 2008 02:43 PM
