Collant Question
Old Jan 19, 2012 | 08:45 PM
Mrauto50's Avatar
Collant Question
I have a 2005 Evo and yes I have popped out the freeze plug under the water neck two times now going to 3rd and getting into boost. This is a new MAP 2.3, ported head with HKS head gasket L19 head bolts. Yes the head has been retorted. I used OEM plugs & Green LT. Has anyone tried to lower there coolant pressure with 50% water/glycol mix, or water/Evans coolant?
Old Jan 19, 2012 | 08:57 PM
n2oiroc's Avatar
what radiator cap are you using?
Old Jan 19, 2012 | 09:58 PM
My03evo's Avatar
Are u not running any coolant or something?
Even if it was a bad cap and it didnt vent the coolng system shouldn't build up that much pressure IF that if what's blowing it out. Its weird cuz I would think a hose or something would blow off system if so.Maybe bad hg and its pressurizing the cooling system?
Old Jan 20, 2012 | 04:04 AM
Mrauto50's Avatar
Stock rad and cap. running 50/50. I'm going to run a pressure test on my coolant system today.
Old Jan 21, 2012 | 05:05 PM
My03evo's Avatar
What happened with the pressure test? and did you let it run without it pressurized and see if it builds pressure on its own indicating a bad head gasket?
Old Feb 1, 2012 | 01:16 PM
Mrauto50's Avatar
I did a coolant pressure test. Set it at 15psi. Let it run. No movement at all in the gauge. Did the 2step. The pressure dropped a hair to 13 to 14. I ran the car up and down the road at 26psi boost. No more issues.
Old Feb 1, 2012 | 01:22 PM
05blue8's Avatar
So it just fixed itself?
MacMan
Feb 2, 2014 10:06 AM
yenny
Aug 27, 2012 05:41 PM
evoxsi
12
Oct 16, 2010 04:26 AM
ExViTermini
Nov 25, 2007 08:19 AM
justink08
26
Jun 26, 2006 05:18 PM
