Replacing water pump
Old Aug 27, 2012 | 01:52 PM
yenny's Avatar
Do I have to drain the coolant to replace the water pump?
Old Aug 27, 2012 | 02:00 PM
Corbin09's Avatar
Put a pan down. Coolant will come out when you remove the rad hose and pump.
Old Aug 27, 2012 | 02:39 PM
masonh's Avatar
yep,you will lose some.
Old Aug 27, 2012 | 02:50 PM
yenny's Avatar
muchas gracias, well it's good to know I won't have to actually drain the coolant, instead just catch some with a large pan
Old Aug 27, 2012 | 03:24 PM
tsidrift1's Avatar
I would drain the coolant from teh radiator first. Nothing worse than pulling the water pump and having coolant go all over your timing pulleys etc.
Old Aug 27, 2012 | 05:41 PM
yenny's Avatar
Oh ok, so yes do drain the coolant PLUS put a pan under b/c more will drip, got it
Weathergeek
Jan 12, 2015 06:19 AM
1fast97gsx
Sep 17, 2013 07:14 PM
Northchuck
Lancer How Tos / Installations
May 1, 2010 05:19 PM
Enzo1089
Apr 13, 2010 02:32 PM
Darius@AMS
Nov 12, 2007 09:04 AM
