Clutch/flywheel and CMC Install prices?
Old Nov 10, 2015 | 09:23 AM
Highkilla11's Avatar
I had a Competition Clutch Stage 2 clutch installed in my car and after about 30k miles it decided to die on me. I brought it to a shop near my house and decided to do a Competition Clutch stage 3 clutch with an upgraded flywheel as well as the MAP CMC for which they quoted be $3,800 out the door. Does this seem a bit high? It was dyno'd at about 340 hp with the bolt ons that I have,.
Old Nov 10, 2015 | 09:44 AM
shekaar's Avatar
What all does that $3800 include? Clutch, CMC, and labor?
Lots of shops around me quote around $900-1000 for a clutch install, my shop is a bit less though. Definitely not a cheap install.
Old Nov 10, 2015 | 12:15 PM
Clutch, CMC, Labor, and all of the fluids. It's just the quote and they are hoping to get it done under that. Just figured that parts were $1100-1200 + labor for $1300-1400 + $100 max for fluids = $2,700 or so. $3,800 seems a little on the high side
Old Nov 10, 2015 | 12:46 PM
shekaar's Avatar
It definitely does seem a bit on the high side, even including everything in the quote. Shop around with the reputable guys near you, see if you can find something a little more reasonable.
Old Nov 18, 2015 | 07:01 AM
Gan-san's Avatar
That's quite pricey and I would say you're getting ripped off if you get done there. I took my other X to a reputable tuner shop and only costed me close to 2k with comp clutch, flywheel, and cmc altogether.
Old Nov 18, 2015 | 07:05 AM
jakgal04's Avatar
I bought all my own parts (comp clutch stage 3, lightweight flywheel and CMC) so whatever that total was from MAP, the labor for the install was $1300 for installation of everything.
Hotsauce101
Apr 27, 2015 09:40 PM
itsbonestock
Dec 21, 2013 09:33 AM
L888Apex
38
Jul 30, 2012 07:23 AM
murlo26
Oct 27, 2010 08:18 AM
