Alteernatives to OEM X Exhaust Manifold
Old Jan 11, 2016 | 12:30 PM
iroc_g's Avatar
So having trouble finding a reasonably priced used X exhaust manifold for my RA swap. I want to stay cast and retain all the OEM heat shielding, plus I'd really like to keep a stockish appearance and keep the wife "happy"...
I know of the MAP SS manifold, but from what dyno charts I have found, it delays turbo spool about 400 RPM from the OEM piece and I din't want to decrease spool at all. I know 400 isn;t much, but I am purposely under building this car to achieve the best spool possible. Any suggestions?
Old Jan 11, 2016 | 12:44 PM
e_kobz's Avatar
Just get a stock X manifold. I'll have one for sale in the next couple weeks cause I'm swapping out my stock manifold for the MAP cast investment manifold
Old Jan 11, 2016 | 01:38 PM
iroc_g's Avatar
For sure, drop me a PM once it;s off and you know it;s not cracked. Apparently, that's why I can't find one and was hoping for an aftermarket option
Old Jan 11, 2016 | 01:44 PM
splattj's Avatar
MAP's is really the only alternative I'm aware of. It is a really nice piece though. Maybe with some ceramic coating and porting of the stock turbo you could see closer to stock spool.
Old Jan 11, 2016 | 02:48 PM
e_kobz's Avatar
Porting slows spool FYI
Old Jan 11, 2016 | 03:28 PM
iroc_g's Avatar
Really? I've been reading on this alot the last few nights, and it seemed the consensus was that porting helped, and that the shorter the distance from head to turbine the better.
Old Jan 11, 2016 | 06:48 PM
redlightrunner's Avatar
porting helps on the top end not the lower anyways.
MisUnderStood
35
Dec 28, 2015 08:54 AM
nollij
15
Nov 28, 2014 10:59 AM
EvoIXMR
11
Mar 18, 2008 07:31 PM
