Cobb and ETS Fitment
Old Jan 29, 2016 | 09:55 AM
EvoNo0b's Avatar
Anyone here running a ETS exhaust and Cobb test pipe or have any experience with it? If so, hows the fitment? Any feedback would be appriciated.
I have a 2015 MR I'm not sure if that would make any difference.
Old Jan 29, 2016 | 10:00 AM
e_kobz's Avatar
If its all OEM replacement then it should fit
Old Jan 29, 2016 | 10:15 AM
ETS Michael's Avatar
Both items are OEM fitment and work together. We also offer a HFC if you would prefer to run all ETS parts :P and can use the Cobb mapping with our HFC.
Thanks,
Michael
Old Mar 12, 2016 | 02:04 PM
haxr303's Avatar
I'm running this combo and have a slight fitment issue. I have a 2015 MR as well. I had a fitment issue before the addition of a cobb DP and ETS TP though. I'm using an ETS quiet. I have also added the exact same resonator in the exact same spot that ETS offers with their system. But again the fitment issues were apparent before that.
1. The tips were a bit closer to the defuser height wise than i'd like (on stock hangers)
2. Tip alignment issue. The tips themselves appear to be equal lengths, but you can tell that the pipes behind the tips extend further out on 1 side. When you look at the muffler compared to the license plate/defuser piece, you can clearly tell that the muffler is not perfectly centered and throws the tips out of whack a little bit.
Cobb DP > ETS TP > ETS quiet
03redtype-s
Oct 17, 2015 06:02 PM
ticaaal70
May 20, 2015 01:02 AM
Turbo01s2k
Nov 25, 2014 06:58 PM
evo jason
Apr 21, 2013 02:56 PM
BoosterX
Nov 8, 2012 04:39 PM
