Comp stage 3 TOB issue?
Old May 26, 2017 | 07:05 PM
whatsav8's Avatar
Hi everyone! first post as I have been a long time lurker lol. Just looking to see if any of you have ran across an issue similar to mine or can give me some advice. Long story short, this is my first clutch replacement. 2014 Evo x GSR full bolt ons, FP green, E85, etc. Previous owner had a comp stage 3 clutch in it, and I recently just ordered another Competition Stage 3 clutch and had the flywheel resurfaced. So I Installed the new pressure plate, new throw out bearing, torqued everything to spec, etc. and when I threw the trans up and mounted the bell housing up/tightened it down, I see that my throw out bearing is not engaging properly. I used all the new components that came with the new Comp stage 3 clutch, including the new TOB. It clicks into place, but it will not "lock" itself. Obviously when I pull back on the clutch fork it should not pop the TOB out. However, the TOB seems to be "clicking" in place properly...How come it won't lock? I uploaded a youtube video to show further what I am talking about. I posted the link below. Any advice is appreciated, thanks so much!
Old May 26, 2017 | 08:41 PM
Rasperin's Avatar
Did any metal fall out when you opened the inspection grommet? This seems similar to my situation where the wave spring broke and it doesn't truly lock into place.
Unrelated this weekend is going to suckkkk.
Old May 26, 2017 | 08:57 PM
whatsav8's Avatar
None at all man! that is what mind boggles me. Everything went on smoothly..
However, I am thinking that I might need to tighten the pressure plate bolts down a little bit more, or put ALL the bell housing bolts in and torque them to spec? Maybe the TOB is not engaging due to the bell housing not being torqued all the way around? It is tight and sealed, but perhaps not enough?
Or maybe even apply more force than just my hand to see if it actually sticks (on the fork lever)
Yeah this weekend will suck lol. Especially if I have to pull this trans again by myself
evowner17
Aug 6, 2014 12:47 PM
dkslvr06evo
11
Aug 22, 2013 07:00 PM
srivera2010
May 27, 2013 10:42 PM
My03evo
Mar 14, 2011 01:32 AM
