gtx3076 build
Old Jan 20, 2018 | 06:07 PM
jerc9's Avatar
gtx3076 build
Hey guys.
I have had my evo for close to 2 years now and im in the process of collecting the parts needed for DD gtx3076 build.
I am trying to achieve a reliable 400whp on pump gas since e85 is not an option. Currently my parts list consists of.
ETS 3" intercooler and piping
Garrett gtx3076r stock frame turbo
Map investment cast manifold
Rexpeed downpipe
Ams high flow cat
Turbo xs catback
Radium fuel rail, regulator, pulse damper
id 1050x injectors
Aem 340lph
Radium dual catch can kit
Gfb mach 2 recirculating valve
Grimmspeed 3-port
Aem intake
I am not sure what else is needed for a 3076 build so any knowledge you guys can give me would be appreciated.
thanks.
Old Jan 21, 2018 | 08:43 AM
RazorLab's Avatar
Cams would help but you will make 400whp DJ with that turbo, stock cams and 91 with a good tune.
For sure do not need the radium rail and regulator. Keep your OEM setup there for less headaches.
Old Jan 21, 2018 | 09:38 AM
e_kobz's Avatar
Good collection of parts so far. Like razorlab said ditch the fuel rail and fuel regulator. The only two modifications you need to make to the fuel system is the injectors and fuel pump, which you have already purchased. 400whp should be easy with that turbo, even on 91.
Ahyesican
68
Jul 5, 2014 03:55 AM
semartinez
Jun 23, 2013 08:30 PM
tzoyi
Apr 18, 2012 04:06 PM
skyseer
Jan 31, 2012 05:29 PM
MRadjahoe
40
Jan 20, 2012 09:27 AM
