Need To Find Oil Pressure Guage Reducer/Adapter
I plan to install an oil pressure gauge. I read a guide on how to install the gauge that tells me I need a:
3/8 BSPT Male to 1/8 NPT Female Reducer
to go from the oil pressure bung on the side of the engine block, which is this weird 3/8 BSPT size. To the standard 1/8 NPT size you typically see on oil pressure gauge sensor cables.
I can't find one of these adapters anywhere and all the links I've found are old as hell and lead nowhere.
Can anybody provide me with a link to order one?
http://www.streettunedmotorsports.co...k_of_block.htm
You need this to remote mount the sensor. The vibration of direct mounting will quickly kill most aftermarket sensors.
Nice, thanks. I was gonna get the AMS remote adapter, but from what I read, even though it was meant for the 4B11, didn't have the correct threads. Which is why I wanted the reducer I mentioned.
I Don't see how the oil cooler banjo's would be an effective place to measure pressure, the flow through them is effected by the thermostat. Also, oil temp should be measure in the pan. The drain plug is large to be drilled/tapped for 1/8" NPT for a temp sensor.
I couldn't find the actual Ralliart P/N's, but here is the set I was talking about from Arnside. I assume those are aftermarket, but they might be the real thing. I don't remember the Mitsubishi parts being red, though.
I agree with this, with proven data. I had my oil temp sensor in the same location as my oil pressure sensor (filter housing) and it would barely ever get over 160f and then I moved it to the pan (MAP oil pan) and the temps in the oil pan where 30-40F higher and it goes above 200F on a 70* day, like normal.
Not sure you meant to reply to me. I have the MAP pan so there is an extra NPT bung you can swap for a sensor, independent of the drain plug.
Spoolin4g63
33
Nov 17, 2010 06:22 PM
1BADSS/SC
Dec 7, 2009 05:26 PM
omniprobe
Sep 8, 2008 11:57 PM
yesevo
Feb 20, 2007 03:54 AM
Grog
Jun 23, 2005 10:36 AM
