Left Rear Wheel Shaking
Old Feb 25, 2018 | 05:21 PM
red_evox_87's Avatar
Hey Guys,
so I was cruising on Highway doing 80 mph and all of sudden my car started shaking massively.
Car seems fine when I am doing around 25 or 30 mph so I thought may be wheels are out of balance. I got wheel balance and alignment done right away but left rear wheel is still shaking.
Decided to put car on all the jack and saw left rear wheel wobbling along with Axle.
Close up left rear diff/ Axle socket
I've removed the rear axle and inspected Axle and Rear diff but not sure about what's the issue. Any pointer or help is greatly appreciated.
Old Feb 25, 2018 | 10:17 PM
►EvolutionX◄'s Avatar
Axle looks good to me, I think you've got a bent wheel. Hit anything hard recently?
Check for Horizontal and vertical play with wheel off ground. If there is no play then its likely a bent wheel, rotate the tire to the rear right or somewhere up front and see if the vibration goes with it.
Old Feb 26, 2018 | 06:38 PM
Thank you for your response. I don't remember hitting anything hard recently to be honest. I just check vertical and horizontal play but it seems ok.
I took out all the wheels from mine and put them on my friend's evo today. He didn't experience any issues with my wheel.
Old Mar 1, 2018 | 04:48 AM
Update: Changed rear axle and rotate my tires too. However, rear driver side only wobbles when I am accelerating. Car seems fine the moment I take foot off the pedal.
Old Mar 7, 2018 | 08:36 PM
laxhero2's Avatar
How many miles on the car? Possible bad wheel bearing?
Old Apr 7, 2018 | 02:34 PM
Front Passenger Axle boot leaked and broke the inside of the axle. It was the side that connects to t-case which made it look like t-case was the issue. Changed the axle and everything is back to normal.
digdat
Lancer Troubleshooting
41
May 28, 2012 10:57 PM
streetracerkam
Apr 14, 2009 06:59 PM
ralliarts MVP
Apr 7, 2006 02:14 PM
CheeseLog
11
Jun 26, 2004 02:39 AM
kromix
Nov 2, 2003 08:10 PM
