Evo x turbo not spooling
Old Apr 14, 2019 | 11:40 AM
Itachlazcano21's Avatar
I got a evo x this January. It’s on e85 ets intercooler dump pipe j pipe tubor thing. I recently changed the clutch. After a few days the car was running perfect and strong. Until one night I took my dad on a drive and as I hit boost it stopped all of the sudden and car hasn’t boosted since. I check for leaks and all hoses are good literally all good. But I found out the car didn’t have a bpv or any sort of bov. So I bought one and just put it in. The car isn’t boosting or you can’t even hear the turbo. When I stepped on the gas the car sounds like it’s leaking air kinda. I don’t know what it is
Old Apr 15, 2019 | 11:00 AM
splattj's Avatar
Take the intake pipe off and check the compressor wheel. Does it spin freely? Is there excessive shaft play? Could well be that running the car without a BOV/BPV killed your turbo.
Old Apr 15, 2019 | 12:01 PM
Metal_AF's Avatar
Can you post a pic of your engine bay? I'm curious about what the bov-less setup looks like with a stock turbo. Did you do a boost leak test? If you are hearing "leaking air" and not making boost, a leak is the #1 suspect.
-Also - where in Ohio are you? I'm on the south side of Columbus.
