Driveshaft Shop Carbon driveshaft broken
I used DriveshaftShop's carbon fiber driveshaft, which felt great but broke at 397whp/500N⋅m.
It was correctly installed and used for 1.5 years, when one morning the full throttle broke at gear 2.
Also the after sales service was very poor. Hence, I would not recommend their products.
yikes. I feel like alot of these mechanical carbon components out there still hasn't been tried and tested enough. This goes for any brand. I think we will start seeing many more failures of carbon mechanical parts in the future.
You can't run carbon shafts next to extra hot exhaust components like catalytic converters. The radiated heat will cause exactly what you see here. The resin melted and the shaft failed.
I almost bought that exact part, hoping the reduced weight would make the acceleration more responsive. The master tech I know talked me out of it. He told me that he has seen instances where the CF driveshafts break, leading him to believe that they are not as reliable as OEM. I did not believe him then, but I did forgo buying the aftermarket carbon fiber driveshaft.
Agreed.
Agreed.
Agreed.
Agreed.
Originally Posted by RallySport9
Resin will not "melt" or even become brittle when exposed to heat (unless very extreme) after its been catalyzed cured especially if cured by autoclave like these driveshafts are. cfrp is designed to withstand very high heat. I personally don't think it had much of anything to do with it being near the cat. That's just the center of most stress and I think it simply failed.
I'm not sure what resin's DSS uses. But most hot cure stuff can handle about 300*C. That cat that appears to be within an inch of the driveline will run at over 800*C. Heat is 1000% what failed this driveshaft, even if it happened slowly over this 18mo time frame. The heat or what fatigued it. His car doesn't even make that much torque; 370wtq is nothing.
Catalysts create "extreme" heat. On a pull that cat will be glowing bright orange, just like the manifold collector at the turbo flange.
