Rear differential leak
Old Apr 26, 2023 | 01:27 PM
LAKE9.EVO's Avatar
Question Rear differential leak
Did an oil change today on a bridge and noticed my rear diff was wet with fluid/oil. I check all my reservoirs including the dynaqueen one in the trunk every 2-3 weeks or so and it hasn't gone down for at least half a year.
Is this something to worry about? My car isn't tuned excessively (330HP) but I push it pretty hard.
Old Apr 26, 2023 | 07:13 PM
RobbieOh's Avatar
5 Year Member
If that was my 10, I would definitely worry. Leaking diff, who knows how much fluid is still in there.. Have you found the source of the leak?
Old Apr 27, 2023 | 05:26 AM
mitsuatb's Avatar
FYI - Res in trunk if that is ACD or AYC should have ATF not Diaqueen Gear oil. Pinion seal is likely going bad. Not an expensive part but will take someone who knows how to do it to get the preload reset correctly. Also check to see if there is any other lines above that area. I have IX RS so I have nothing in the trunk but wiper fluid.
Old Apr 27, 2023 | 08:09 AM
splattj's Avatar
The ATF for the ACD/AYC will smell noticeably different than the Diaqueen/Gear oil. If the oil from your leak is super stinky, it's gear oil and likely seeping from a bad seal.
Old Apr 28, 2023 | 05:41 AM
LAKE9.EVO's Avatar
Thanks for clarifying that, I'll message my tuner and see if they noticed this leak in the past
sloAZevo
Jun 15, 2012 10:27 PM
aka.ralliart15
Jan 25, 2011 05:13 AM
lv05evo
Nov 7, 2010 10:50 PM
Thegame
11
Jan 11, 2010 03:49 PM
