Evo X cover valve baffles
Old Jan 29, 2024 | 10:25 AM
d_evox_l's Avatar
Hi All,
I removed baffles to powder coat the cover and do I need to re-add atf sealer? if so, which one will you recommend?
thank you for your time
Old Feb 7, 2024 | 07:46 AM
Eric13's Avatar
Personally I did not add any sealer, only red Loctite for the bolts to hold the baffles. I have a ~2000 miles without issues, just pulled the motor to work on another issue and none of my bolts are out of place. I'll be re-powder coating the valve cover again and doing the same thing.
Old Feb 7, 2024 | 07:58 AM
schuhie's Avatar
I haven't ever done a X, but on my 9, I did as Eric said. Red Locktite on the bolts and a "scratch" on the bolt and baffle to check for movement over time. I have about 10k miles on mine and the bolts haven't moved at all.
Old Feb 9, 2024 | 05:13 AM
d_evox_l's Avatar
sorry for the late response, and yes thank you very much, this confirms my question
Old Feb 9, 2024 | 08:55 PM
ViciousLSD's Avatar
with red locktite - my allen wrench would slip if I try to remove my fasteners!!
skatermsmn
22
Mar 28, 2013 03:24 PM
tsidrift1
May 2, 2011 12:33 AM
