Sponsored by:
Sponsored by: CARiD
Ralliart scooped
Old Jan 9, 2008 | 06:45 AM
thj17's Avatar
Ralliart scooped
might interest some of you guys
http://carscoop.blogspot.com/2008/01...rt-240-hp.html
Old Jan 9, 2008 | 08:54 AM
nongan's Avatar
Hmmm, X diluted.
Old Jan 9, 2008 | 09:06 AM
XRS's Avatar
XRS
Mmmm, me likes.
Old Jan 9, 2008 | 09:07 AM
LanEvoNine's Avatar
But I bet its probably a lot lighter than the X.
Old Jan 9, 2008 | 09:11 AM
Vostok 7's Avatar
And let the rending of garments begin!
If anything, it's probably going to be heavier than the X. Why? Less aluminum panels.
Unless the old AWD system was significantly lighter than the SAWD, which I doubt, then the Ralliart will probably be the same or more heavy than the X.
- Patrick
Old Jan 9, 2008 | 09:17 AM
EzeE1o's Avatar
i think it will be lighter...im guessing its not as reinforced as the evo x, doesnt have brembo brakes, etc
Old Jan 9, 2008 | 09:21 AM
EVO X Owner-2-B's Avatar
Regular Lancer fenders?! All you guys wanting to upgrade your rims will be limited with those. Time to get the fender roller out or do some major body work.
Old Jan 9, 2008 | 09:49 AM
StevenStarke's Avatar
looks like an evo 10 to me
Old Jan 9, 2008 | 09:52 AM
Asta4125's Avatar
- Patrick
??????What are you talking about? I highly doubt the ralliart is going to be heavier. Actually I am almost 100% sure that it wont. The panels, are soo over rated its not even funny. What are we talking about total...maybe 25-30 pounds big whoop. The ralliart will use the same awd system that will be in the X. It will be ligther due to less options. Navigation...heated seats..leather...big brakes....smaller rims..ect. I would def be game for a car like this...
Old Jan 9, 2008 | 09:54 AM
EzeE1o's Avatar
Originally Posted by Asta4125
... It will be ligther due to less options. Navigation...heated seats..leather...big brakes....smaller rims..ect. I would def be game for a car like this...
i heard that the navi will also be avail....and heated seats? i have not read anywhere of any US lancer that will have heated seats
Old Jan 9, 2008 | 10:01 AM
XRS's Avatar
XRS
The car itself will be a bit smaller (width) and I bet less sound deadening. Take a GTS and add the weight in for the AWD and turbo. All in all, im guessing it will probably weigh in maybe 100 - 150 pounds lighter than the X.
Old Jan 9, 2008 | 10:08 AM
Nichiren's Avatar
my GTS has heated seats ... but im in canada
Old Jan 9, 2008 | 10:19 AM
atombomb33's Avatar
EvoM Community Team
Don't forget to add in the weight for the SST, FMIC, UICP, LICP, etc, etc. Still won't weigh as much as the Evo but it might be pretty darn close. Either way, it won't be light either
Old Jan 9, 2008 | 10:34 AM
blitzkrieg79's Avatar
Yep I pretty much agree with you on the potential weight of an AWD Ralliart as it will be basically based on a regular Lancer chassis (not the reinforced heavier Evo X chassis). Current GTS with CVT weights in at 3109lbs (GTS with manual tranny weights in at 3032lbs), slap an AWD system (which won't be the same as found in Evo X but more similar to US spec Evo IX AWD) along with a reinforced engine with a turbo and you can add about 150-200 pounds to the GTS which will give you around 3200-3250lbs for the manual tranny version and probably around 80lbs more for the SST version.
Either way, the car will probably offer a 5.6-5.8 0-60 time (similar to WRX).
Old Jan 9, 2008 | 06:23 PM
SpeedI2acerX's Avatar
sunofa*****!!!!!!!!!!!!!!!!!
