Sponsored by:
Sponsored by: CARiD
Evo X training videos, Look
Old Jan 28, 2008 | 03:43 PM
sabotaaage's Avatar
interesting how theres no 'reverse' haha
Old Jan 28, 2008 | 03:49 PM
DirectorSe7en's Avatar
Very corny! But very informative.
It's that classic intro:
*Works on something*
*notices the camera*
"Oh hey, I didn't see you there"
LMAO!
Old Jan 28, 2008 | 04:23 PM
itsme4g63's Avatar
nice, seems like reverse gear is not going to whine since its actually 1st gear.
Old Jan 28, 2008 | 04:39 PM
cksdayoff's Avatar
LMAO!
Old Jan 28, 2008 | 04:54 PM
biggie5252's Avatar
Gotta love training videos.
Old Jan 28, 2008 | 05:26 PM
Mmelmann's Avatar
"If a problem develops with the shifting of the transaxle, replacement of the whole unit is required"
So don't get the twin clutch transmission unless you are a glutton for punishment! It'll be another 5 speed for me that's for sure.
I bet that the Evo X will respond to a tune and exhause just as well, if not more, than my old IX... especially with the bigger turbo, intake mani, and exhaust manifold. Come on Shiv, figure that ECU out! You can dooo eeeett!
Old Jan 28, 2008 | 05:41 PM
Revoart's Avatar
Did you here? The X's turbo is bigger than the previous Evo's
Old Jan 28, 2008 | 08:24 PM
Vostok 7's Avatar
Meh, I think this is more of a situation of it being a Getrag built unit, not a Mitsubishi built one. No need to rend garments and proclaim the end of the world just yet.
Besides, being Getrag it should be practically indestructible. If the BorgWarner units in the VW's have been any indication, the units are pretty solid unless you do something particularly wrong (as in something you're not supposed to).
You guys are just all scared because it's just something new you don't understand.
- Patrick
Old Jan 28, 2008 | 09:05 PM
Mmelmann's Avatar
- Patrick
I am not scared of something I don't understand, I understand how it works and I also understand that most of us buy Evo's and WRX's to tune them and add power in order to get more enjoyment from our purpose built speed machines.... they aren't ordinary commuters after all. I also understand that a piece like a twin clutch transaxle is not an inexpensive item. From what the tech video says... if it isn't shifting properly, then it can't be repaired like a failed clutch pack or flywheel can... the whole damn unit has to be replaced and I understand that a mitsubishi dealership wouldn't exactly jump at the opportunity to just give you a new one. Our modifications to the car translate to added power, and that added power gets translated directly to the one thing that can convert the engine power to the rest of the transmission... the clutch.
Mi save mucho. Mi still no save why you wouldn't answer my post over at nasioc as to why you insist on putting your name at the end of every post. I'm teufelhund over there.
-Russ
Old Jan 28, 2008 | 11:50 PM
Vostok 7's Avatar
It's just something I do, mmmkay?
Anyhoo, I don't think that the SST is going to be as big of an issue as everyone makes it out to be but we'll see.
Besides, they said that in the future they will be able to work on them, just not right now.
- Patrick
Old Jan 29, 2008 | 01:30 AM
machron1's Avatar
Originally Posted by evo_soul
i like the beginning of the 4th video. lol translation is, if your SST Tranny is F#&$ed you gotta replace the whole thing, if we learn to fix something in the future, we will let ya know
"Learning to fix them" is not really the hurdle, nor necessarily a hurdle at all technically. I find it difficult to imagine Getrag does not have detailed repair instructions available in some capacity already, and I also find it difficult that given said instructions, and parts to perform the job, a mechanic worth their salt couldn't perform any necessary repairs to it. In the military we repaired systems (aircraft) all the time considered "unrepairable" in the field, so long as higher-level maintenance, or the manufacturer rep (or ultimately of course, the unit commander as needed), signed off on it. We didn't have access to the highest-level repair manuals, but the tasks in the manuals we did have were all clearly distinguishable as Unit-level or Intermediate Maintenance-level. Doesn't mean we didn't do all 3 levels if necessary, just means there are different systems in place that normally perform the work, due to parts stock, tools availability, security, expertise, etc.
I currently work in the auto industry in an R&D capacity. It's pretty much a guarantee that any failures with the new TC-SST will be sent straight to the or Getrag (or probably both eventually) test engineering facilities/labs where they will do a full failure analysis of the materials and design, and identify the failure mode. Initially, the goal is to get a failed gearbox back to the lab in pristine condition so as not to disturb the evidence (much like CSI). After enough failure analysis data is collected and (hopefully-not-so) routine failure modes are identified, along with their signs and symptoms, detailed failure analysis is less likely, unless a problem develops that could possibly lead to a TSB or recall.
Also, since they (normally) assume they will warranty the majority of these transmission in the first few years of existence , there is no need to build a replacement parts and special tools infrastructure for them, only to re-design certain parts again, and have stale parts/tools on the shelves marked for disposal. It is also impossible to guarantee, when a part IS re-designed, that a service technician will use the correct revision if obsolete revisions were ever delivered, not to mention the waste of money getting all the stuff out in the first place.
So...long story short, don't worry about it never being field-repairable. It's still just a transmission, made of parts and bolted together, just as any other. It's not welded together or anything, they just don't plan on having their new gizmo field-repairable for a couple years is all. But believe me, once they come to grips with the new design and why it might fail, they are going to want to stop all the expensive shipping of transmissions all over the world in short order (if only to save on shipping costs).
Eventually most of the units (or parts therein) will be refurbished and placed in service again after they fail, and not simply tossed in a bin. Probably not the first few failures, as they will probably require destructive inspection on many of the parts, but after normal failure modes are established and easily identifiable, you better bet they won't just toss their little babies in the trash bin.
Old Jan 29, 2008 | 01:42 AM
evo_soul's Avatar
sounds like someone has a job with plenty of work when and if these things start failing. I just hope and pray Mitsu didnt rush this one. Putting it in the rally art was ballzy too.
so far so good, nothing else on the lancer has failed with the CVT, well at least that i know of.
Old Jan 29, 2008 | 10:32 AM
Vostok 7's Avatar
Excellent post, machron1. Totally makes sense as that's why they are not repairing them initially.
- Patrick
Old Jan 29, 2008 | 11:15 AM
How about where they talk about overheating?!
Why is that even a possibilty? Damn that makles me nervous to drive hard.
Old Jan 29, 2008 | 11:24 AM
FiftyFive's Avatar
Am i the only one that can't access these?
