Sponsored by:
Sponsored by: CARiD
weird evo x problem, anyone?
Old Feb 10, 2008 | 01:36 AM
SRT4 to Evox's Avatar
Old Feb 10, 2008 | 02:25 AM
Geaux's Avatar
Originally Posted by SRT4 to Evox
-the Car is never at 0 rpm, unless the engine is shut off, car is always idling at
.5 - 1 rpm always, not sure if that should be normal on evos or anything.
Hrmm, from my knowledge, I believe ALL cars do that man if not highter.
Sorry, can't help you about your other problem though.
Old Feb 10, 2008 | 02:39 AM
really?! did not know that, I dont remember my srt4 ever idling at 1rpm all the time.
Old Feb 10, 2008 | 02:51 AM
buffaluphagus's Avatar
When my car is cold it idles around 1k, once at normal operating temp idle goes down to about .5 every car i have owned is that way. I also owned an srt4, seems about the same to me. I have not had any trans or stalling issues. maybe you are having some kind of clutch issue, poping out of gear, stalling. I dunno, i would take it to the dealer.
Old Feb 10, 2008 | 02:57 AM
yeah maybe ima see how it goes, only had the car for about 2.5 weeks now with
just over a 1000 miles on it.
and it rarely happens, but just the fact that it happened thought that was a bit sketchy
Old Feb 10, 2008 | 02:58 AM
cdupont03's Avatar
Theres no way it would be at 0 RPM unless it was shut off. I dont really understand what your talking about.
Old Feb 10, 2008 | 03:15 AM
i just never noticed my rpm going up and down,
so now that i know it seems to be normal?
Old Feb 10, 2008 | 09:31 AM
EvilEvo9MR's Avatar
" The RPMs are never at 0 unless the car is shut off?"
Every car under the sun does the same thing RPMs "Revolutions per minute" which is when the engine is running it is spinning making Revolutions and all RPMs are is a monitor of how many times the engine spins or makes a revolution per minutes I really don't understand what you were really saying there
Old Feb 10, 2008 | 09:42 AM
evo_Eks's Avatar
what gear does it pop out. when i had my cobalt 5th gear pops out @ random. most people i asked suspects bad synchros. idk!
Old Feb 10, 2008 | 10:06 AM
DSMEVOLUTION's Avatar
What is this guy talking about??? Have you ever operated a motor vehicle. I can understand the tranny problem your having, personally I would take it right back to the dealer. As far as idling, how in the h^ll can a car idle at "0"???? It wouldn't be idling if it was at zero it would be shut off as you may have noticed....
Old Feb 10, 2008 | 10:27 AM
DylanPS's Avatar
Why would the car be idling at 0 rpm? Most well-tuned, or well-made cars should maintain a constant idle.
Old Feb 10, 2008 | 10:46 AM
thuan's Avatar
Guys stop giving him a hard time,
I think he was trying to say the car idle from 500 to 1k
alot of time the NEW X wants to stall. because it seem like it wants to dip under 500
Please read this
https://www.evolutionm.net/forums/sh...d.php?t=324215
Old Feb 10, 2008 | 01:13 PM
STi2EvoX's Avatar
The eratic idle will be fixed either by a dealer reflash once a tsb is put out for this, which surely it will, or a tuning reflash. The only think so far with the car that really concerns me is the shifter popping out of gear. I have not heard this from anyone else, but that doesn't sound good, as it's likely to only get worse over time. I guess it could smooth out over time as well, but I'm a pessimist. Hopefully I'm wrong, or that this problem is unique to your evo, because I'm buying one in about a week and really don't want to have any problems with it. I hope you get it worked out. Goof luck, and let us know about that cel.
Old Feb 10, 2008 | 01:18 PM
Cabo's Avatar
Probably because it never did. I would guess that it idled between 500 and 1000 RPMs.
Cabo
Old Feb 10, 2008 | 02:40 PM
Jameson_IXMR's Avatar
I believe he means with just the key in the on position without the engine started the rpm needle moves up a little. Thats fine, that is only power being applied to the electrical synchros/servos to drive the gauge.
