Sponsored by:
Sponsored by: CARiD
Daytime Running lights
Old Aug 3, 2008 | 03:13 PM
mksevo's Avatar
Originally Posted by Slimdatwelve209
still wouldnt matter if you have the base evo X pullin the fuse wont make the drl go away i believe it only work with SSS evo x that has the stock HID
That is CORRECT only EVO X SSS with the HIDs.
good luck to the others hopefully some will post a bypass for yall as well.
Old Mar 23, 2011 | 09:05 PM
kenshin1015's Avatar
Can
for canbus system im assuming you have the fast key system right? no key? not a regular key?
Old Mar 24, 2011 | 11:35 AM
User71421's Avatar
I didn't like the color of the DRL's very much, so I swapped them out for some blue 'fake-hid' bulbs. They actually look pretty dang good.
The bulb sizes are '1156' for the DRL's and they're really easy to swap in and out. (The bulbs are only about 10 dollars for a pair, too)
Old Mar 24, 2011 | 11:57 AM
EvoXjavi's Avatar
one of mine blew out...so just took them both out...they're dumb anyways, i hate those lights.
Old Mar 26, 2011 | 08:18 PM
Finest's Avatar
Originally Posted by kilgoja
i never understood the point of drl...they are annoying to me...actually can make it harder to see an oncoming car cuz of the brightness if they are aimed wrong...i mean it just doesn't make sense...cant u see the car fine without them?...as far as foggy or rainy weather...just turn ur lights on...common sense...glad my ix doesn't have drl
It's not so that you can see during the day, it's so that others can see you.
Old Mar 26, 2011 | 08:23 PM
Sufu's Avatar
If other cars can't see you in the daytime, I think you have bigger problems than what a DRL can fix. Either way I replaced my drivers side DRL bulb twice, then it died again.
I removed that stupid DRL fuse, no more DRLs for me.
Old Mar 27, 2011 | 02:14 PM
DuffmasterFresh's Avatar
I know there is a DRL bypass for the normal Lancers and it should work with the EVOs (Non SSS-Halogen lights). I soldered up my own bypass but this one is basically the same thing: http://cgi.ebay.com/ebaymotors/ws/eB...ht_2207wt_1161
You can use it with HIDs so they function normally or you can keep your standard lights and it should just get rid of the DRL.
Old Mar 27, 2011 | 02:39 PM
HudsonFalcon's Avatar
We know JRox well he's a member of this forum and a good guy.
MalibuJack
May 25, 2017 06:46 PM
evoinit
May 22, 2006 04:20 AM
Go Trees
Canadian Forum
Jul 8, 2004 05:20 AM
