EVO X gears
Once the car is tuned, it will make power all the way to redline. Buschur was seeing continuous power being made even without a tune and some bolt-ons. This won't be an issue at all.
Dont believe me, go talk to people in the Drag racing forum i.e. Warrtalon and others.
In this class of vehicle, for that amount of money, it should have been standard issue. They had the perfect opportunity with the new model.
There's not a guy in the world who wouldn't want and be willing to pay for a 6th overdrive gear for highway cruising. How much could it have possibly cost?
They just didn't want the manual to be quicker/faster than the TC-SST.
It's all about marketing.
They better have that TC-SST working perfectly when it appears or Mitsu is going to take a big hit in the crotch.
Once again:
Tire Diameter 25.6
Final Drive Ratio 4.687
1st Gear 2.86
2nd Gear 1.95
3rd Gear 1.44
4th Gear 1.1
5th Gear 0.76
1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear
RPM MPH RPM MPH RPM MPH RPM MPH RPM MPH
2500 14.3 2500 21.0 2500 28.3 2500 37.3 2500 53.7
2600 14.9 2600 21.8 2600 29.4 2600 38.8 2600 55.8
2700 15.4 2700 22.6 2700 30.6 2700 40.3 2700 58.0
2800 16.0 2800 23.5 2800 31.7 2800 41.7 2800 60.1
2900 16.6 2900 24.3 2900 32.8 2900 43.2 2900 62.3
3000 17.1 3000 25.1 3000 34.0 3000 44.7 3000 64.4
3100 17.7 3100 26.0 3100 35.1 3100 46.2 3100 66.6
3200 18.3 3200 26.8 3200 36.2 3200 47.7 3200 68.7
3300 18.9 3300 27.7 3300 37.3 3300 49.2 3300 70.9
3400 19.4 3400 28.5 3400 38.5 3400 50.7 3400 73.0
3500 20.0 3500 29.3 3500 39.6 3500 52.2 3500 75.2
3600 20.6 3600 30.2 3600 40.7 3600 53.7 3600 77.3
3700 21.1 3700 31.0 3700 41.9 3700 55.2 3700 79.5
3800 21.7 3800 31.8 3800 43.0 3800 56.7 3800 81.6
3900 22.3 3900 32.7 3900 44.1 3900 58.2 3900 83.8
4000 22.9 4000 33.5 4000 45.3 4000 59.6 4000 85.9
4100 23.4 4100 34.4 4100 46.4 4100 61.1 4100 88.0
4200 24.0 4200 35.2 4200 47.5 4200 62.6 4200 90.2
4300 24.6 4300 36.0 4300 48.7 4300 64.1 4300 92.3
4400 25.1 4400 36.9 4400 49.8 4400 65.6 4400 94.5
4500 25.7 4500 37.7 4500 50.9 4500 67.1 4500 96.6
4600 26.3 4600 38.6 4600 52.1 4600 68.6 4600 98.8
4700 26.9 4700 39.4 4700 53.2 4700 70.1 4700 100.9
4800 27.4 4800 40.2 4800 54.3 4800 71.6 4800 103.1
4900 28.0 4900 41.1 4900 55.5 4900 73.1 4900 105.2
5000 28.6 5000 41.9 5000 56.6 5000 74.6 5000 107.4
5100 29.1 5100 42.7 5100 57.7 5100 76.0 5100 109.5
5200 29.7 5200 43.6 5200 58.8 5200 77.5 5200 111.7
5300 30.3 5300 44.4 5300 60.0 5300 79.0 5300 113.8
5400 30.9 5400 45.3 5400 61.1 5400 80.5 5400 116.0
5500 31.4 5500 46.1 5500 62.2 5500 82.0 5500 118.1
5600 32.0 5600 46.9 5600 63.4 5600 83.5 5600 120.3
5700 32.6 5700 47.8 5700 64.5 5700 85.0 5700 122.4
5800 33.1 5800 48.6 5800 65.6 5800 86.5 5800 124.6
5900 33.7 5900 49.4 5900 66.8 5900 88.0 5900 126.7
6000 34.3 6000 50.3 6000 67.9 6000 89.5 6000 128.8
6100 34.9 6100 51.1 6100 69.0 6100 91.0 6100 131.0
6200 35.4 6200 52.0 6200 70.2 6200 92.4 6200 133.1
6300 36.0 6300 52.8 6300 71.3 6300 93.9 6300 135.3
6400 36.6 6400 53.6 6400 72.4 6400 95.4 6400 137.4
6500 37.1 6500 54.5 6500 73.6 6500 96.9 6500 139.6
6600 37.7 6600 55.3 6600 74.7 6600 98.4 6600 141.7
6700 38.3 6700 56.1 6700 75.8 6700 99.9 6700 143.9
6800 38.9 6800 57.0 6800 77.0 6800 101.4 6800 146.0
6900 39.4 6900 57.8 6900 78.1 6900 102.9 6900 148.2
7000 40.0 7000 58.7 7000 79.2 7000 104.4 7000 150.3
7100 40.6 7100 59.5 7100 80.4 7100 105.9 7100 152.5
7200 41.1 7200 60.3 7200 81.5 7200 107.4 7200 154.6
7300 41.7 7300 61.2 7300 82.6 7300 108.8 7300 156.8
7400 42.3 7400 62.0 7400 83.7 7400 110.3 7400 158.9
7500 42.9 7500 62.9 7500 84.9 7500 111.8 7500 161.1
7600 43.4 7600 63.7 7600 86.0 7600 113.3 7600 163.2
7700 44.0 7700 64.5 7700 87.1 7700 114.8 7700 165.4
7800 44.6 7800 65.4 7800 88.3 7800 116.3 7800 167.5
7900 45.1 7900 66.2 7900 89.4 7900 117.8 7900 169.6
8000 45.7 8000 67.0 8000 90.5 8000 119.3 8000 171.8
8100 46.3 8100 67.9 8100 91.7 8100 120.8 8100 173.9
8200 46.9 8200 68.7 8200 92.8 8200 122.3 8200 176.1
8300 47.4 8300 69.6 8300 93.9 8300 123.8 8300 178.2
8400 48.0 8400 70.4 8400 95.1 8400 125.2 8400 180.4
8500 48.6 8500 71.2 8500 96.2 8500 126.7 8500 182.5
Tire Diameter 25.6
1st Gear 2.86
2nd Gear 1.95
3rd Gear 1.44
4th Gear 1.1
5th Gear 0.76
You show 62.1 at 2900 rpm in 5th and I have 3000rpm at that speed.
The only difference I see is you are using tire diameter and I'm entering a tire size (245/40-18) so, obviously, the programs are a little different.
Anyone have a real car? Can you see a 100 rpm on your tach? What is 62.1mph in RPM. LOL
these speeds per gear its real or in the speedoo? this is important...
maybe im wrong.. but this car is too short, you must change the gears to many times and this lose TIME.
and the worst thing is that you must spend to much gas doing a trip with it..
high rev all the time...
maybe who have the car can give us your opinion!
