Sponsored by:
Sponsored by: CARiD
Another TRU-Boost question
Old Mar 4, 2008 | 11:14 PM
EvoX_SA's Avatar
I have it all in an installed, but I am only making 10 psi of boost. I have the duty cycle set to 70% and the spring pressure/wastegate crack pressure set to 8.00.
Is anybody else running this EBC and what are your settings. Please I beg you.
Old Mar 4, 2008 | 11:16 PM
PDXEvo's Avatar
Sounds like you have hooked up something wrong, and the car is running wastegate. Funny thing is, wastegate is 12psi, not sure why you are getting 10.
Old Mar 5, 2008 | 04:36 AM
EvoX_SA's Avatar
does the car have an internal or external wastegate. The Aem has different hook -up depending on type of wastegate , maybe that is part of the problem.
Old Mar 5, 2008 | 09:42 AM
EvoX_SA's Avatar
Nobody, well I guess I'll try to figure it out myself.
Old Mar 5, 2008 | 10:01 AM
8thWonder's Avatar
You probably need to keep turning the duty cycle up. That's part of the reason I got rid of mine. It was waaay too complicated to get it dialed in.
Old Mar 5, 2008 | 10:03 AM
EvoX_SA's Avatar
I think am going to keep trying. Does anybody know if the turbo has an internal wastegate. i am assuming it does but I'm not for sure.
Old Mar 5, 2008 | 10:11 AM
PDXEvo's Avatar
Internal wastegate. Look at my install guide here.
Old Mar 5, 2008 | 03:54 PM
EvoX_SA's Avatar
Thanks for the help it is working now. Around 23.75 psi at peak and tappers to about 19.7-20 at redline
arpad
179
Feb 9, 2020 03:51 AM
lbcevo
Sep 10, 2013 09:06 AM
adriano_917
Mar 19, 2012 07:31 PM
IDRINKV8
Apr 4, 2006 07:17 AM
