Sponsored by:
Sponsored by: CARiD
service engine soon light
Old Apr 9, 2008 | 03:56 PM
mmachac's Avatar
ok so i bought my car 5 cars ago and as i drove off the lot the SES light came on and they told me it was just the gas cap (salesman told me this) so i reset it and it came back monday morning and i took it in and they said its a timing code that the car got stuck in retarting itself and all they did was clear the code. so it came back on this morning and im going to take it in tomorrow to see what it is. the only thing iv gone to the car was put a blow off valve on it VTA one and plugged up the hole where it used to go into the intake. could this be the problem? i put the BOV on saturday. need some help
Old Apr 9, 2008 | 04:01 PM
UT_Evo's Avatar
First thing you did was put a VTA bov on a X? I'm gonna say that's your problem just so you take it off. Did you want that "pish" sound? I hope you say yes, because otherwise... WHY!?!?!?
If that isn't the cause of the problem then officially: Welcome to Mitsubishi.
Old Apr 9, 2008 | 04:03 PM
wroblewskievo's Avatar
did the light come on again after the bov install? if yes then i would say thats your problem. your car is going to run like crap with that bov.
Old Apr 9, 2008 | 04:10 PM
mmachac's Avatar
no it came on a couple of days after putting the BOV on. and why would the car run like crap? it didnt make any difference but make a pish sound
Old Apr 9, 2008 | 04:42 PM
jpelton37's Avatar
from what I have been reading and what others have told me in person, if you have a BOV and it is not on full recirc, you will have a lot of issues with the car stalling and idling badly. Car is designed for full recirc, an aftermarket CAI will give you the whoosh sound (from the stock BOV), and not mess up the car.
Old Apr 9, 2008 | 04:43 PM
atombomb33's Avatar
EvoM Community Team
Put your flame suit on...I can already feel this thread heating up.
You don't need the BOV. Put the stock BOV back on and see if that fixes the SES light.
Old Apr 9, 2008 | 05:08 PM
scottatyamaha's Avatar
Why? Most likley dont even bother going to the dealer put back on your stock BOV and you should be fine. Consider this a lesson learned.
Old Apr 9, 2008 | 05:13 PM
broddey's Avatar
The car will not respond immediately to DRASTIC changes such as a VTA blow off valve when it is designed for a recirculating type.
It normally takes at least one cycle of driving around and shutting the car off before the car confirms something is wrong, and thus triggers the check engine light.
In short, swap the bov for the stocker, pull the neg terminal on the battery (in that order), replace the neg terminal of the battery, and see if it fixes your problem.
Old Apr 9, 2008 | 05:16 PM
OK I found this thread and you may have the same problem as this guy. Something to do with retarded timing during start up. You might want to take it to the dealer.
https://www.evolutionm.net/forums/sh...d.php?t=336149
I hope this code does not turn out to be the p0300 code of the EVO X
Old Apr 9, 2008 | 05:38 PM
mmachac's Avatar
what is the p0300 code? and what about those BOV that recirculate and VTA at the same time a guy at a performance shop was telling me about it?
Old Apr 9, 2008 | 05:42 PM
emagdnim8's Avatar
What's the point of this?
Old Apr 9, 2008 | 05:51 PM
When the EVO was first released in the US in 2003. They were plauged with a SES light for p0300 which was random cylinder misfire.
Old Apr 9, 2008 | 07:27 PM
Joe's Evo X's Avatar
The car is running rich as it is. When you add the BOV every time you let off the gas it is going to run extra rich since it is not recir. I have a bov that i can set to 50 - 50 and that hasnt giving me any problems. But ya i am sure it is the BOV causing this.
Old Apr 9, 2008 | 08:09 PM
mmachac's Avatar
alright thanks for the help. what brand of 50-50 BOV do you have
Old Apr 9, 2008 | 08:48 PM
PDXEvo's Avatar
Just to clarify, this is on an X right? If so, whats the code.
