Sponsored by:
Sponsored by: CARiD
Accelerating issues
Old Apr 15, 2008 | 11:23 AM
Scrumby's Avatar
Question Accelerating issues
Accelerating issues
i have bought the X 3 weeks ago by now i have about 700 miles on it. it is my first evo and i'm kinda confused as of why some stuff is happening to it.
when accelerating in first, second and third gear after 6k rpm seems to lose boost.
also in first gear sometimes seems to stall after 4k like it jumps or something not to sure how to explain it but it's weird.
Any advise would be appreciated.
Old Apr 15, 2008 | 11:26 AM
raph's Avatar
Go to your dealership and have them reflash your ECU that Mitsubishi just released for the X.
pltek's Avatar
if you do some digging, it might need a flash that will correct your problems
Old Apr 15, 2008 | 11:48 AM
Scrumby's Avatar
ok thank you i will try to call them up today and see if they know anything bout that
Old Apr 15, 2008 | 11:57 AM
SilverEvoX's Avatar
The boost is going to continue to taper off as you get higher into the rpm's, nothing wrong with it, just the way the stock turbo boosts. Manual boost controllers can help it not lose as many psi on the top end but it will still taper back from peak boost my a couple psi.
Old Apr 15, 2008 | 12:03 PM
Scrumby's Avatar
i see
do you guys have some advise on high rmp launches i have tryed it once and seems like i smoked the clutch when i attempted it is that normal or did i just not do it right?
sorry for all them newbie questions it's my first evo ) just enjoying the power of it
Old Apr 15, 2008 | 01:14 PM
Mightygnu's Avatar
Originally Posted by Scrumby
i see
For the X, you have to disable the Factory 2-Step. Its a little switch high up on the clutch. I did it to mine and am still having issues.
Old Apr 15, 2008 | 05:08 PM
buffaluphagus's Avatar
Scrumby, just rev to limiter and drop the clutch. Nice break in bro.
Old Apr 15, 2008 | 05:40 PM
Scrumby's Avatar
i was at the dealership today and they upgraded my rom. well i still smell the clutch from time to time not sure what i'm doing wrong i have not yet attempted to drop the clutch at 7k scared to break the clutch or something
at what millage would it be recommended to drive the car like that?
Old Apr 15, 2008 | 05:59 PM
Boostd4's Avatar
Dropping the clutch at 7K rpm will get you the same results as doing the same thing in an Evo 8/9....it will break things.
Don't do it.
Old Apr 15, 2008 | 06:01 PM
Boostd4's Avatar
Accelerating issues
Boost tapers near redline...so you are losing boost.
Scrumby's Avatar
so what would be the best rpm to launch on?
Old Apr 15, 2008 | 06:03 PM
Scrumby's Avatar
Thanks for your advise i really appreciate it.
Old Apr 15, 2008 | 06:06 PM
si_to_evo's Avatar
5.5K lol
Old Apr 15, 2008 | 06:08 PM
Scrumby's Avatar
Thanks
and thank you all for answering my silly questions
