Sponsored by:
Sponsored by: CARiD
Air Filter Mod - Negative or Positive?
Old Apr 28, 2008 | 10:23 PM
aznxkaiser's Avatar
http://www.evoxforums.com/forums/sho...ed=1#post51786
This guys dyno shows that after the cone his power significantly dropped. It is unknown though, if its just the ECU holding back as it is still learning. I also do not know if he disconnected and then reconnected the battery.
Old Apr 28, 2008 | 10:31 PM
apex_silver's Avatar
i like the dif but im going to use a hks hybrid drop in only becouse i dont want the voided warranty
Old Apr 29, 2008 | 09:47 AM
Rudager's Avatar
I'm gonna use the Works Drop-in Filter myself
and yeah he prolly didn't reset his ECU
Old Apr 29, 2008 | 11:08 AM
NoJoy's Avatar
I e-mailed K&N about their Evo air filter for the X, but they said it was not out yet. I read an article ( I can't remember the magazine) that said they got a dyno increase of 15-25hp for the K&N air filter! I want to try this when they come out. By the way is the X air filter different than the IX?
Old Apr 29, 2008 | 12:09 PM
no0odlez623's Avatar
with the stock maf housing, an inverted filter (filter caves in at the top) and after the factory reflash you lose hp... idk why but it does.... however some guy got the inverted filter before the reflash and it added i think 10 whp?...but either way just go with a flat top filter unless you get an intake that comes with an maf housing.
Old Apr 29, 2008 | 03:31 PM
wa2evo's Avatar
air filter
i got the cheap autozone filter with concave top and felt nice before factory flash, after factory flash car felt alot slower. havent reset ecu yet. will do it this afternoon and take for a drive and see if it helps. will post results
Old Apr 29, 2008 | 04:21 PM
aznxkaiser's Avatar
Couple of Questions..
Does disconnecting and reconnecting the battery reset the factory reflash I got?
What does a flat top cone filter look like?
I got the red one from Autozone...
Old Apr 29, 2008 | 04:35 PM
dont bother... some tuner on here did some major testing and found after the flash the filters with the concave top will lose hp wether you reset the ecu or not....
find a K&N filter!
Old Apr 29, 2008 | 04:38 PM
well im assuming you got the specture filter...(i have the same kind) if you have the reflash...go back to stock for now...a drop in filter or a flat top filter will make power....if you do not have the reflash i think you are making around 10 whp? anyway a flat top filter or a drop in filter is best now... there are some tuners that have made power with an inverted filter...but that was before the reflash and they had a custom maf housing...so i cant really say for sure if an inverted filter is bad.
Old Apr 29, 2008 | 04:43 PM
aznxkaiser's Avatar
Ok thanks...I just wasted teh moneys =(
So resetting the ECU doesn't take away the factory reflash?
Should I just go buy a Flat top filter made from K N ?
Old Apr 29, 2008 | 06:30 PM
no reseting the ecu does not take away the reflash
and as long as its not a inverted cone filter it should make power... but be aware this is with the stock maf housing... i cant really say for sure if an inverted cone filter is bad with a different maf housing...
anyway gst did the reserch and im just letting you know what i learned from that...if you want to read more about it...https://www.evolutionm.net/forums/sh...d.php?t=341608
Old Apr 29, 2008 | 07:30 PM
si_to_evo's Avatar
Anyone know the part no.?
Old Apr 29, 2008 | 11:20 PM
Web9's Avatar
K&N drop in filter - Part #33-2392
Old Apr 30, 2008 | 05:57 AM
Noize's Avatar
EvoM Administrator
I used a self modded cone at first and definitely lost power. It has something to do with velocity stacks IIRC. If you want a filter, go with one from a reputable company like Buschur or AMS. They dyno test their products so you know you are getting something that generates horsepower, not hype.
I have been using a Works drop in with good results if you want something like that.
Old Apr 30, 2008 | 02:00 PM
Tunerhead's Avatar
+1
Got the WORKS drop-in filter on mine. Haven't dyno'd it yet but will do in the near future.
