Sponsored by:
Sponsored by: CARiD
Vibration
Old May 22, 2008 | 01:52 PM
txfoster's Avatar
Vibration
When I first got this car the driveline vibrated pretty good at 80 and then would go away around 90 ish. Had tires balanced = cured.
Finally crossed the 120 mark and begins to vibrate and gets worse all the way to 160. Had tires checked again no out of balance no bent rims.
Could this be a drive line problem. Has anyone been up that speed mark and had same problem?
Sorry this a driveline vibration no engine that always buzzzez my butt.
Old May 22, 2008 | 01:55 PM
SpeedI2acerX's Avatar
sh*t i vibrate all the time! especially when its cold but goes away. not sure what it is. havent gone pass the 100+ mark though
Old May 22, 2008 | 03:16 PM
evolution_X_GSR's Avatar
Went 120mph on the hwy with no vibration.... hrm, not sure why you guys are experiencing that... Hopefully you'll get if figure out... good luck...
Old May 22, 2008 | 03:32 PM
Mightygnu's Avatar
I just noticed some vibration while driving regularly. I think I will put the car up on stands and check everything out.
Old May 22, 2008 | 05:26 PM
yeah if it doing it while your driving then its definitely a problem. around here its nothing but sh*tty roads so i cant tell but on the freeway she drives smooth as butta,
Old May 22, 2008 | 05:34 PM
stanrc's Avatar
i dno't have the evo, but the steering wheel in my gts gets very shaky at around 80 and i've already had the tires rebalanced once a few weeks ago.
Old May 22, 2008 | 05:41 PM
Asta4125's Avatar
At any rate...is the vibration comming from the steering wheel, or from the floor. Usually the floor means driveline vibes, and the steering wheel usually means tires balanced, or loose ball joints. I highly doubt its a ball joint. If your tires are still in balance, I would check to see if your driveshaft is properly balanced.....
Old May 22, 2008 | 05:55 PM
Kwiq Niss's Avatar
140+, no vibration.
Old May 22, 2008 | 10:50 PM
STi2EvoX's Avatar
mine's got a rattle in the shifter cage somewhere, my guess is a little lube or a tightening of a couple bolts would correct this. Hmmm... mine only does this in 5th gear, which is strange. I am guessng it has something to do with the reverse lockout mechanism that engages when in 5th. My STi had this after a short throw shifter install because the reverse lockout cable rubbed on the driveshaft, so I had to zip ties it away from it to prevent this from happening.
Of course my X has done this from the get go before I even put my short throw shifter in, so that definitely didn't cause the issue. TX Foster, try holding the shift lever to the left or the right when your in 5th and getting the rattle and see if the noise goes away. If it does, than it should be easy to narrow down the issue. I've been meaning to take the center console out and then go for a drive to see exactly where in the shifter cage the noise is coming from so I can fix it. Maybe we have the same rattle?
Old May 23, 2008 | 05:47 AM
Stangar's Avatar
To solve TIRE problems, you need to check this site to find where the closest "Hunter Road Force Balance System" is located to you. You won't have to drive far. Click on the "star thing" in the center and input your info.
It works and they will solve any TIRE vibration problems. These machines, and the people trained to use them, are the best.
http://www.gsp9700.com/
Old May 23, 2008 | 10:43 AM
dek0026's Avatar
i get a slight vibration the gravel setting in the rain and running on the hwy at like 70-80. figure it is just the tires dealing with the extra water on the ground.
Old May 23, 2008 | 12:32 PM
Stangar's Avatar
Oh, and one more thing.
These are high performance tires. When it is cooler outside (less than 55 deg), these tires will take 10 or 12 miles of driving to heat up and return to being perfectly round. After sitting all night they kind of develop a flat spot where they've contacted the ground.
kwinters
Lancer Tranny/Drivetrain Tech
10
Nov 16, 2017 04:20 PM
Evo Pilot
22
Oct 26, 2009 05:41 PM
zebra4
Aug 29, 2009 08:44 AM
Evo a Mula
Aug 20, 2009 05:39 AM
shimla
Aug 12, 2005 09:25 PM
