help w/ "unbalanced/misaligned" rim
Old Aug 11, 2005 | 09:52 PM
shimla's Avatar
my brother borrowed my car while i was away on vacation. he hit a curb and got my right rear rim scratched a bit...not too bad. when i had my tires rotated i noticed steering wheel vibration. had my tires balanced and they found the same rim w/c was scratched to be " mis aligned or oblong"( not sure about the term) w/c is causing the vibration when it was placed in the front when it was rotated...the guys at the tire shop suggested that i have the rim "aligned" by a specialty tire center. do u guys have any suggestion on my problem? thanks!!
Old Aug 11, 2005 | 10:02 PM
feldguy's Avatar
An alignment is totally different from balancing. In order to get rid of the vibration, you may have to have the tires swapped when you rotate to leave that rim on the rear of the vehicle. You should check the cars alignment too, just in case there was damage or it knocked something out (happened to me). If the rim is bent, sometimes balancing it will not effect it. Most often I can get rid of high speed unbalanced vibrations, but there is more of a thump, and its always there, not at the appropriate harmonic speeds. Swap the tire and balance the rims, it'll be perfect.
Old Aug 11, 2005 | 10:04 PM
evo_il8's Avatar
i say it is a perfect time to put some new shoes on that eb
Old Aug 11, 2005 | 10:19 PM
shimla's Avatar
thanks for the advice and comment....sorry for not too sure about the term...yup, the wheel is bent that's why the only way to have it fixed according to the tire shop is to have the ent on the wheel fixed by a specialty tire shop.....does anyone know one here in chicago area? really am temted to get new shoes but don't have the budget for it....too busy saving money to pay this car off sooner...also am thinking of trading this car in and take advantage of the 0% on a new MR...my dealer just called me to say they have an MR that they will give at invoice...very tempting......much better i guess than the crappy 5.2 % 72 mos deal i got....oh well, back to earth....wld u guys think just get 1 enkei rim from people here trying to sell their orig enkeis?
Old Aug 11, 2005 | 10:21 PM
shimla's Avatar
sorry for the typos, old notebook and getting ready to sleep
Old Aug 12, 2005 | 06:50 AM
jdoc7's Avatar
Try Wheels America at 3017 Malmo Drive Arlington Heights 847-734-9212
http://fixrim.com/index.htm
They did a set for me that turned out nice. $99 per rim
Old Aug 12, 2005 | 09:25 PM
shimla's Avatar
^thanks......only thing is that when i checked the site it says $129 flat rate for rim repair....what did u have repaired on urs? how long did it took? how does the whole procedure go?
lznk41
17
May 2, 2020 07:18 AM
kwinters
Lancer Tranny/Drivetrain Tech
10
Nov 16, 2017 04:20 PM
nmilsaps
15
Jun 26, 2011 08:50 AM
SpeedI2acerX
Nov 23, 2007 01:22 PM
davids2004
Lancer Troubleshooting
19
Jul 22, 2006 11:37 AM
