Sponsored by:
Sponsored by: CARiD
does anyone know the part # for the MR steering wheel?
Old May 31, 2008 | 01:26 AM
JWA's Avatar
JWA
Originally Posted by Parikh1234
yeah ive been looking for this all over but cant even find a picture. Any ideas?
Ok, here's where I saw it. You go to the Australian site, then the Lancer section, then Accessories. That should be this page here: http://www.mitsubishi-motors.com.au/...lancer&id=3028
From there, select Interior (bottom left), then the second option is Bluetooth Hands Free Kit. It mentions that "Note: The accessory Bluetooth Kit differs from the OE Factory Fit kit".
Here's a screenshot to save you a bit of time:
Attached Thumbnails does anyone know the part # for the MR steering wheel?-bt.jpg
Old May 31, 2008 | 06:26 AM
edofloat's Avatar
MR Steering WHeel Part #
The part number for the MR steering wheel is 4400A179 sells for $565.17 This includes the back cover which has the cutout for the BT switch. This part isnot shown in the picture but is part of the assembly you get the weheel and the cover by ordering this part number. If you want to order contact me.
Old May 31, 2008 | 08:51 AM
JWA's Avatar
JWA
Originally Posted by edofloat
The part number for the..
Nice info edofloat. Do you know anything about the window switches? I've been wondering if it's possible to install auto-up/down switches on the windows other than the driver's side: https://www.evolutionm.net/forums/sh...13#post5721813 Thanks.
Old May 31, 2008 | 09:03 AM
edofloat's Avatar
have to check
I'll have to check, I suppose if it can be programmed, I'll look it up and see, I'd like that too on the front passenger side. May take a few hours to get the info but I can find out.
Old May 31, 2008 | 10:45 AM
Parikh1234's Avatar
Thats awesome! Ill bring that to my dealer. The US button set has three buttons, do you know which button is missing in the AU switch and why?
The part number for the MR steering wheel is 45024A sells for $565.17 This includes the back cover which has the cutout for the BT switch. This part isnot shown in the picture but is part of the assembly you get the weheel and the cover by ordering this part number. If you want to order contact me.
Thats awesome. Can you get the part # for the above AU switch?
Old May 31, 2008 | 11:00 AM
JWA's Avatar
JWA
I haven't used the bluetooth setup, but it appears to me that it has an "answer" and "end" button, and is missing the button that you push to initiate voice dialing. I don't know if it uses one of the other buttons for that or how t does it. I'd think that it should be possible though. Not that it is listed on the AU site under the Lancer accessories. It should be the same for the Evo, but they don't have the Evo X accessories section up yet over there.
Old May 31, 2008 | 11:12 AM
edofloat's Avatar
...checking...
Old May 31, 2008 | 11:17 AM
edofloat's Avatar
There are two part numbers for the switches, one for the master set and one for the other doors. These isn't a switch shown for an auto down to be added to the master cluster or the passenger door. You might be able to buy the msater set and puck out the drivers switch and add it to an exisiting switch set but it wont do much but give you an indent.
I have checked and have been unable to find a way so far to enable this with the MUT III. Dug around and found the limits for open and closed and how to trouble shoot and such, but haven't seen a way to do this yet. I'm not the master of the scan tool, so I'll ask the person who is Monday.
Old May 31, 2008 | 11:46 AM
JWA's Avatar
JWA
^ Awesome - thanks edofloat.
You're location says Upper Midwest - I'm in Racine, WI, where are you at?
Old May 31, 2008 | 04:55 PM
edofloat's Avatar
Duluth
Old May 31, 2008 | 07:54 PM
JWA's Avatar
JWA
That is "upper" . Thanks again for all of the info.
Old May 31, 2008 | 08:25 PM
RussellM's Avatar
Plat Vendor
That isnt a part number in the illustration -- that is only a reference number.
Old May 31, 2008 | 09:16 PM
beetle_orange's Avatar
man, is there a way to ensure the bluetooth switch on the dash will work for us? i would be all over it. russellm? that bluetooth switch on the dash simply makes life a lot easier.
Old Jun 1, 2008 | 04:42 AM
Parikh1234's Avatar
damm, good thing i didnt call my dealer looking for that part
Old Jun 1, 2008 | 08:10 AM
edofloat's Avatar
the part number is 4400A179
