Sponsored by:
Sponsored by: CARiD
Is Gravel Mode Faster Than Tarmac Mode??
Old Jul 31, 2008 | 05:35 PM
  #46
VincentX's Avatar
Originally Posted by goofygrin
ASC != AYC
No. ASC is a computer that controls the attitude of the brakes to rotate and slow the car down. AYC is a computer controlled active rear differential that's only meant to increase performance.
Old Jul 31, 2008 | 05:52 PM
  #47
Jooyoung99's Avatar
Yeah, I know it's counter intuitive. I didn't believe it either until my friend who races professionally in China showed me how to drive this car. But remember that my car has a modified suspension, and a racing slicks. So it might be different for a stock EVO X.
Originally Posted by machron1
WOW a full second. that's actually huge. appears i'm wrong given my limited experience as stated. i had already considered auto-x might lend itself to asc full off given its low-speed, yank and bank nature. but gaining a full second on a road course with it off is nuts! i do believe you, i just can't wrap my head around the reasons behind it. i wonder how it's possible? why on a road course do slip angles greater than those allowed with asc half-off produce better times? normally the fastest road course work is smooth, tidy, and free of huge tail-out action except maybe in the tight hairpins.
from what I've felt, the slip angle the asc allows is ample, and greater than i normally would induce on the track. of course I've never tracked an x, but i have lots of track time in my VIII. also, for the OP, did you try the tarmac, snow, and gravel settings out?
Old Jul 31, 2008 | 07:09 PM
  #48
Hiboost's Avatar
What does ASC stand for exactly?
ACD, AYC, S-AWC I'm all familiar with but the abbreviations are out of control.
Old Jul 31, 2008 | 07:15 PM
  #49
VincentX's Avatar
^Active stability control.
  #50
truDriver's Avatar
ASC = Active Stability Control ... damn, to late
Old Jul 31, 2008 | 07:17 PM
  #51
Kracka's Avatar
Originally Posted by dek0026
isn't the only difference between tarmac, gravel and snow the clapping time/duration of the acd? not actual power distribution.
Correct, don't listen to any of the other people who speak before realizing they don't have a clue.
Old Aug 4, 2008 | 10:44 AM
  #52
Jooyoung99's Avatar
Track even results at this thread:
https://www.evolutionm.net/forums/sh...80#post5968280
Old Sep 10, 2008 | 02:03 PM
  #53
Aseller's Avatar
Wow, extremely informative thread. Answered all the questions to the one I just started. Thanks!
Old Sep 10, 2008 | 03:06 PM
  #54
dek0026's Avatar
dude read your manual. ASC = anti skid control. not active stability control.
Old Sep 10, 2008 | 04:18 PM
  #55
Jooyoung99's Avatar
I really should the read the damn thing. I always thought it was Active Stability Control, like in the Outlander. Good catch. I'm a little smarter because of it.
Old Sep 10, 2008 | 05:28 PM
  #56
CaliMR's Avatar
Originally Posted by Jonasan50
I'm no computer guru, but if someone can look it up, you will find how all the mags in the past have gone over this many many times.
Magazines are often wrong. I have seen articles where they have said both ways in the same article. Look at a diagram of the ACD, it is fixed 50/50
Old Sep 11, 2008 | 03:32 AM
  #57
dek0026's Avatar
if you read it you will learn that asc is just a traction control. meaning it won't cut out the revs on you if you lose a little bit of traction like when launching or power sliding. SAWC functions as an "active stability control" which is comprised of several systems like you see in other cars. the stand out with the evo is the ayc. most cars with stability control don't have an as sophisticated yaw control like we do.
push the button once turns off your traction control. holding it down turns off the stability control and traction control but maintains the yaw control.
the difference driving modes (tarmac ect) adjust the acd's clamping timing and duration. regardless of what mode you're in pulling the hand brake while moving puts the acd in a free state allowing you to slide without the computer trying to correct it.
the only way the different modes would make you fast is which one slows you down the most in corners and how good of a driver you are.
/thread
Old Sep 11, 2008 | 06:32 AM
  #58
gunzo's Avatar
/thread
Strange .. your manual is different from mine .. mine DEFINITELY refers the ASC as Active Stability Control
Also it says with ASC on it adjusts brakes AND engine power to prevent skid/slip ..
It says the same as yours about the braking control on the AYC though..
I have a feeling something is lost in the translation
http://www.mitsubishi-motors.co.jp/s...evo.html#guide
Anyways..I translated it to english ..
Old Sep 11, 2008 | 06:34 AM
  #59
Aseller's Avatar
Ya know, odly enough mine says the same thing... kaaaraaazzzzyyy!
Old Sep 11, 2008 | 06:38 AM
  #60
Sharkbite2000's Avatar
Those pics are hott very nice.
