Sponsored by:
Sponsored by: CARiD
Lithium battery backup in the Evo X
Old Nov 29, 2008 | 12:37 PM
minime18r's Avatar
Is there a lithium battery backup in the ECU system that prevents the resetting of a SRS airbag light? The manual shows a seperate SRS control module.
I am swapping out the Recaros for Corbeau (no airbag) because I am too wide to sit comfortably in the stock seats and now I have a problem with the seat airbag warning light. I have read most of the threads concerning resetting the ECU's but most say that the backup battery is an issue. Also, read a thread about using a 1 to 1.5 resistor on the plug to defeat the warning light. Can someone help me here?
Old Nov 29, 2008 | 02:53 PM
JoeyM3's Avatar
the srs light cannot be reset by simply resetting the ecu, most of the time the dealer has to turn it off. i dont think anyone has tried the resistor method yet. but my question is, if the srs light is on, are all the airbags non-functional?
Old Dec 1, 2008 | 04:57 PM
minime18r's Avatar
Reboot the airbag light
From what I understand, the light is activated when the connection to the airbag is disrupted, what was an open circuit before becomes a closed circuit, or visaversa. From all that I have read in the forums, the tact of trying to reboot the system by cutting power to the ECU, and then reconnecting is sufficient to eleminate the SRS light as long as as there are no detectable problems in the system. However, if there is an auxillary power supply that allows some memory to persist, then the light will continue to burn. If someone knows the location of the auxillary power(lithium battery), if it exists, I would like to try to see if disconnecting it would cause the light to go out.
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
reklisss
Aug 2, 2011 03:09 AM
dsmbruno
Feb 15, 2009 08:54 AM
rcheung
May 29, 2005 10:16 AM
yannotmi
Lancer Troubleshooting
Jan 14, 2003 09:30 PM
