New EVO X Garrett GT3071R & GT3076R
Hi Guys,
Takes a look at these new turbo from Garrett. They are capabale of producing up to 525hp from that 2.0L engine. Obviously this will require major upgrades to the intake, fuel supply and exhaust and I'm pretty sure internal parts as well.
http://www.autopartsprice.com/auto-p...071r-a-gt3076r-
It's all about the supporting mods with these 2 turbos. The HP figures they quote are general guidelines but based on previous dyno runs and recent gains over that mod level when looking at VDR graphs I'm sitting at around 550 crank HP. I don't think they are the BEST turbo setup in the world but they can be made to work decently.
CBRD made 370whp on his dyno in summer with a FMIC and catback exhaust. Maybe a test pipe... can't remember. Still had the stock O2 housing though which chokes a lot of flow.
the highest we made was 372whp, but torque was about 20-30 less than stock...
we've since made some big changes.... on our own stuff, and made power in the 370s (same mods) and torque +20-30 over stock
cb
cb
Damn, you're getting that much flow out of the 76mm wheel? And you're on the compressor inlet elbow that comes with the turbo right? I bet there are some gains left by going to the ATP 3" inlet elbow with full 3" intake tubing. Not sure what that'll do to the compressor surge margin though.
The intake manifold I'm using showed a ~40 crank HP increase and I'll post a full report tonight. Other tweaks with the different O2 DP and Exhaust manifold gained some more low end torque and held boost a bit better in the mid range. Testing with better compressor outlet pipes and moving to a 75mm throttlebody with larger than 2.5" IC piping will also be done.
On the compressor surge issue I'm working with Gunzo on testing some tweaks on the Mivec tables to make them work as gear based maps instead of temp based maps. Currently there is only surge in 5th gear at around 3400 when going past 20 psi, but if I can have it switch to a Mivec map with very conservative mivec in the 3000-3500 range past 180% load it should reduce the surge quite a bit. Then gears 1st-4th I can use slightly more aggressive Mivec than I do now and possibly get even more spool back.
I'll have more details soon.
