Sponsored by:
Sponsored by: CARiD
Anyone replaced the Higher Rear Spoiler with the lower wing on base model w/Aero
Old Dec 27, 2008 | 06:57 PM
SupremeX's Avatar
Originally Posted by akitamike
Actually, has anyone come up with a way to take the wing off completely and patch the holes and paint them so the trunk lid looks completely stock? I'm not familar with how body shops work, if they are able to fill in holes in sheet metal, or if it's cheaper to try to get a trunk lid from Mitsubishi that doesn't have the holes already drilled into it.
Search, there are several wingless cars on here.
Old Dec 27, 2008 | 07:03 PM
Porkskins's Avatar
Originally Posted by FJF
It'll probably run you $300-400 to have the holes filled/welded and the lid repainted.
Ive been quoted between $300-500 from a few places and most want to fill the holes with fiberglass so it will be "easier" to reinstall the wing if I wanted to...$400 and $500 quotes for welding in plugs from 2 shops. I have a friend who does body work for a living and wants $300 for the welded job, and he would probly do better work than all the shops.
I dont mind the vinyl stickers I have covering the holes so much and will probly hold out to see what the ducktail trunk options are around summer time.
Old Dec 27, 2008 | 07:26 PM
raytrix's Avatar
I think this spoiler technology should of been incorporated into the Evo X. It's simply amazing and works in all driving conditions.
http://www.youtube.com/watch?v=kPKD85mFbkA
Old Dec 27, 2008 | 07:31 PM
gotrnet's Avatar
i am using the gts wing. you have two holes on each side to cover up/plug and then you have to drill one hole on each side for the mounting of the gts wing. i found some nice plugs at Advance and then drilled the other two out myself. very easy and it you look at the trunk you can see where along the edge there are places for the two holes you have to drill. now i can actually see out of my back window.
Old Dec 28, 2008 | 06:09 AM
Robevo RS's Avatar
you are better off if you swap a trunk with your wing on it, with some lancer owner. I did a same with my Old Evo. I didnt even had to paint the trunk. It was a same color. You can even get some extra money for it , instead to spend it.
Old Dec 28, 2008 | 11:30 AM
zoomzoommo's Avatar
How do you actually remove the wing? I see there are nuts, but is there any adhesive involved? I was thinking of removing the wing and using rubber grommets (assuming I can located the proper size).
Old Dec 28, 2008 | 02:18 PM
Jackie Chiles's Avatar
This is a good thread, but if I am lucky enough to get an Evo X, first thing I'd do is yank off that ugly wing.
Old Dec 28, 2008 | 02:27 PM
Teh Rob's Avatar
I think South Coast Mitsu sells the X trunks wingless and with no holes for around $280. They come unpainted so you do have to spend a little to get it sprayed. But at least you'll have your original trunk and wing if you decide to swap back or sell the car.
