Sponsored by:
Sponsored by: CARiD
Anyone replaced the Higher Rear Spoiler with the lower wing on base model w/Aero
Old Dec 26, 2008 | 10:31 PM
akitamike's Avatar
I noticed
Attached Thumbnails Anyone replaced the Higher Rear Spoiler with the lower wing on base model w/Aero-rear-wing-comparison.jpg
Old Dec 26, 2008 | 10:32 PM
akitamike's Avatar
Edit.
Old Dec 26, 2008 | 10:40 PM
aftershock141's Avatar
It will fit in the same holes.
Why would you want to do this though? The mid-win IMO doesn't look near as good. I bought the car with the SSS package just so I could have the higher spoiler and HID projectors.
LuDa's Avatar
the wings fit in the same holes...it wouldnt take u long to find someone with a GTS who is willing to trade.
Old Dec 26, 2008 | 10:52 PM
brads09lancerGT's Avatar
If you have the OPBlue, I'll trade ya in a sec
Old Dec 26, 2008 | 11:20 PM
EvolvedVIII's Avatar
Really? I was under the impression that the big wing had more holes than the base one.
Old Dec 27, 2008 | 06:08 AM
Robevo RS's Avatar
If you will put the Seibon CF replica on it then , one more whole is needed. I guess its a same as the OEM since it is a replica from CF.
The small wing have 2 hole the big one 3.
Also the wholes are in different place , only one is matching. If you take off the cover from your trunk door, then you will see the pre marke wholes for the "big wing". One you have to find out.
Out of 3 -2 holes are different locations.
I had to drill them when i put the bigger wing on it. Although it was a piece cake since they are pre marked, only one is not.
Old Dec 27, 2008 | 07:57 AM
Nex1's Avatar
The lower wing uses 2 holes, whereas the high wing uses 3 holes. I switched from low to high, and had to drill a 3rd hole to fit the higher spoiler. So the low wing will fit on a car with a high wing already installed. You just have to patch up the extra hole.
I have a PB low wing available for anyone that wants one. PM me if interested.
Old Dec 27, 2008 | 09:10 AM
tomatoEVO's Avatar
lower wing is trash. i'm sorry mitsu even offers it. makes the car look like a GTS
Old Dec 27, 2008 | 10:21 AM
jsyang15's Avatar
just debating go big or go home
Old Dec 27, 2008 | 12:29 PM
ZEUS EVOX's Avatar
I think the lower wing is better. Doesn't have that cheap plastic on the insides. Looks cheap if you ask me!
Old Dec 27, 2008 | 03:24 PM
jmorris1027's Avatar
I've got the non sss wing..I'll trade someone plus cash for an sss wing.
Old Dec 27, 2008 | 06:14 PM
mike100's Avatar
I think my standard wing looks more tasteful, but it still is situated in a bad spot and blocks your rear view in a bad way.
Old Dec 27, 2008 | 06:37 PM
akitamike's Avatar
Actuall
Old Dec 27, 2008 | 06:52 PM
FJF's Avatar
FJF
Originally Posted by akitamike
I'm not familar with how body shops work, if they are able to fill in holes in sheet metal, or if it's cheaper to try to get a trunk lid from Mitsubishi that doesn't have the holes already drilled into it.
It'll probably run you $300-400 to have the holes filled/welded and the lid repainted.
