Sponsored by:
Sponsored by: CARiD
How long before brake change?
Old Dec 31, 2008 | 09:12 AM
dragon831's Avatar
How long are people going before having to get new pads? Also, do the front ones wear out before the back ones? When you press on the brake does it apply all 4 brakes? yes i have alot of questions lol
Old Dec 31, 2008 | 09:17 AM
kwanza's Avatar
Depends on how you drive. Spirited driving will result in more wear and tear. Yes all brakes clamp down when you press the pedal. Front wears faster than rear, most of your braking is done with the front.
Best to check the meat on the pads visually, when you rotate tires.
If you hear sqeaking, change pads. If you hear and feel grinding, hopefully you wont need to buy new rotors.
Old Dec 31, 2008 | 09:28 AM
goofygrin's Avatar
Squeaking doesn't necessarily mean your pads are bad -- inspect them.
My pads (not stock) squeal like a **** -- worse than a garbage truck. But they have lots of life left.
Old Dec 31, 2008 | 10:47 AM
ArchieBabes's Avatar
I just changed my front and read pads at 15k miles.
