Sponsored by:
Sponsored by: CARiD
Solo II help
Old Jan 3, 2009 | 12:30 AM
Nsomniac's Avatar
EvoM Administrator
Solo II help
Anyone have a good link that explains modification restrictions for Solo II autocross classes? I've read the manual, but I'm a bit unsure on some things. I'm not sure what options I have between A stock and STX, but I know I don't want to be modding what I can't use on the weekend.
Thanks in advance.
Old Jan 3, 2009 | 01:43 AM
markpaco's Avatar
You'd be running in STU. But as far as AS, you basically can only do the following:
Adjustable shocks
Drop in air filter
Cat back exhaust
R compound tires
Wheels must be the same diameter and width. The offset cannot exceed 1/4" (6.35mm) from the stock offset.
There are other things you can do (harnesses, etc) but they don't particularly improve performance. My recommendation is to learn/appreciate the stock car. Just get an alignment and go straight into STU because the PAX index is better.
Old Jan 3, 2009 | 07:13 AM
goofygrin's Avatar
You can get an alignment in A-stock as well.
Like markpaco sai, you'd be in STU. STU allows you to do this:
- intake
- exhaust (full TBE, but you must retain a cat)
- coilovers or springs/struts
- sway bars
- camber/caster plates
- change wheels
- ss DOT brake lines
- brake pads
- big brake kit
- some aero mods
- no lightening mods
- retune FUEL maps only (no boost modifications, so no boost controllers, boost control in the ECU, etc.)
However, you are limited to a street tire with 140 tread rating or higher and 245 max width.
The "next" step is BSP (this is just the main difference between STU and BSP):
- engine remap/boost control is allowed
- R compound tires
- NO big brake kits
- no tire width limitations
Personally, I feel that the X is NOT competitive in a competitive AS class but it competitive in a strong STU class. If you are running in a PAX class (like Novice) then, even bone stock, STU is a better class to run in.
Scroll down on the main index to the Motorsports section. There's lots of info.
coldsteel82
Outlander Sport
Jan 27, 2017 11:53 AM
honda-guy
Jan 29, 2016 12:44 PM
Solo II Evo
Northeast Region
Jul 21, 2010 08:39 PM
rouin
Dec 15, 2007 06:00 PM
Tsurara
May 5, 2006 11:23 AM
