Sponsored by:
Sponsored by: CARiD
Pillar Pods
Old Jan 4, 2009 | 08:48 AM
switchblade906's Avatar
most people dont drill they just use a good double sided adhesive tape
Old Jan 4, 2009 | 08:58 AM
mrblondelv's Avatar
but then you have the wire or tube that connects the gauge to the proper area hanging out, right?
Old Jan 4, 2009 | 09:57 AM
EvoX_SA's Avatar
I drilled my gauge pod cup directly to the top of the steering column for now. That piece of plastic only 9.85 to replace so I wasn't to worried about it. the wires are not visible and makes for a cleaner look.
Old Jan 4, 2009 | 10:01 AM
aftershock141's Avatar
Do you have a part number?
Old Jan 4, 2009 | 10:52 AM
macPSU's Avatar
Originally Posted by mrblondelv
this is the EVO X, I see you indash Tach is on the left side and odometer is on the right.... it is reversed on my GTS 08... but I like the gauge you have on yours. You just drilled into your steering column, right?
I just used the double-sided tape that came with the gauge. It's not some super adhesive tape but I'd rather it not be stuck on there too good since it's just a temporary fix for me. The firewall was drilled right at steering column and the wires run behind the steering wheel. There is maybe an inch of wire visible behind the gauge if you look for it, but you don't notice it otherwise.
Old Jan 4, 2009 | 11:17 AM
mrblondelv's Avatar
Cool ,bro looks tight.... I think I might have to do that as well....thanks for all your info.
h4ckluserr
13
Feb 26, 2010 07:43 PM
fanbelted
Apr 21, 2009 08:25 AM
grubiaco
Apr 28, 2005 01:56 PM
Bitnode
Oct 10, 2004 08:17 PM
zupber4930
Automotosports - Illinois
Jan 9, 2004 12:03 PM
